B7 A4 2.0TDI Service
harmless Jul 2, 2011
  1. harmless
    harmless Member
    79
    Hi Guys, service is due and im thinking of doing it myself as its the 40k service its been serviced all round by audi before and if its just the usual filters and oil, id prefer to save the money thank shell out for an audi monkey at the stealers..
    my question is what oil are you all using ? Castrol SLX Longlife 3? is there anything else required at a 40k other than usual filters etc.
    it had brake oil change last service so should be ok on that.
  2. rowdyboy
    rowdyboy Member
    804
    19
    Castrol edge.
  3. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    768
    Trans oil if its an auto.
  4. jfarhead
    jfarhead Member
    176
    Make sure the engine oil is VW 507.00 if your engine type needs it (DPF), don't know if the Castrol Edge comes in 506.xx so mentioning it just in case.
  5. harmless
    harmless Member
    79
    Thanks Everyone - jfarhead.. i have a 2.0tdi with DPF, so thankyou for your advice i im sure that audi gave me the 5w40 castrol long life stuff before as the topup oil, but never used it, ive never had to topup oil between services and i dont drive her steady in a long shot..
    ill see if i can find any of that oil you mentioned.
    thanks again
  6. rowdyboy
    rowdyboy Member
    804
    19
    Castrol edge is the correct spec and readily available in Halfrauds or online. They have it cheap in Costco if you have a card.
  7. mm707
    mm707 Member
    282
    castrol edge 35 quid in asda for 4 litres and it is vw 507.00 so will be ok
  8. rowdyboy
    rowdyboy Member
    804
    19
    Check which one it is though as certain ones (I think it's 5w-40) should only be used on fixed service intervals. As you're servicing it yourself, I'm sure you'll be on fixed interval anyway. All the info is in the owners manual.
  9. Dazmo
    Dazmo Active Member
    1,762
    Would have thought it would be a 5W,30 same as my 3.0 DPF but not sure
    Anyway its definatly Castrol Edge you want!
    If you just buy your own oil and take it too audi it will cost you half as much to have it serviced with them, and you will still get the stamp etc. (if thats what you want)
    Or take it to the guys at VAGTECH who do a damn better job than audi at a fraction of the cost!
