B7 a4 2.0tdi 170... Massive mpg drop
Jonbooth Sep 23, 2013
  1. Jonbooth
    Jonbooth New Member
    Morning AllBought the car in June and have regularly got 55 mpg doing my commute to work and back.Mid last week I noticed that the fuel remaining indicator in the car had dropped significantly from where it should be with the amount of fuel left in the tankA further 2 fill ups later and my mpg figures are 38 & 41 Mpg on the 2 tanksThe car is well serviced and although I've had a mass of problems with DPF removal, remapping, an egr cooler pipe, wheel bearings, drive shaft and having to replace both rear springs, the car has been running pretty well up to last week.The only significant change I can think of is outside air temp has fallen from the early to mid 20's to 14 & 15c... If the air intake temp sensor was faulty, would that cause the car to run rich and therefor cause this problem ? Has anyone got any other idea's ? Thanks in advance for any help you can give Car has 129k on it
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,274
    2,788
    Outside temperature is significant, because of the time taken for the car to get up to running temperature from a cold start. How long is your commuting journey?
  3. Jonbooth
    Jonbooth New Member
    Hi JDP....Normally about 30-35 mins and around 27 miles. I wouldn't have thought it would have been cold enough to make such a big difference but I'm happy to be corrected :D .... Do u think that could be it ? Is it better to leave it to warm up before setting off ?
  4. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    883
    Look at the usual suspects such as failing DPF and clogging EGR valve. Both will give you the symptoms your experiencing. Take it for a spirited drive and keep in 4th gear with revs high for about 15-20 mins ensuring the engine temp is optimum. This will start a manual regen and hopefully blow all the **** out of the DPF system.
  5. jdp1962
    8,274
    2,788
    Definitely don't do that. The most efficient way to get an engine up to optimum operating temperature is by driving it (but gently of course). The drop in mpg you describe is probably too big to be explained solely by outside temperature reduction (especially over a 27 mile run). My commute is 11 miles, so it is more relevant.
    As Brodster says, check all the usual suspects.
  6. Jonbooth
    Jonbooth New Member
    Thanks for coming back to me... The DPF has been removed (which is why I needed a new egr cooler, they caught the pipe that drops from the cooler to the side of the block .... £300 .... Keeerrrrrching !!!) .... Are there any other symptoms that an egr valve might give... I'm getting a wining noise when I back of the throttle, my garage has said it's the veins (?) on the inlet manifold cause it's variable (sorry, haven't got the best knowledge of turbo's) Sounds a bit like Darth Vader's battle cruiser. Could that be the egr valve sticking and out if interest, would this cause an underboost fault ? Had an underboost fault when I first got the car in June but haven't seen anything of it since.
  7. Jonbooth
    Jonbooth New Member
    Just as a quick update to this, i removed and cleaned the Mass Air Sensor and reclipped the airbox back to the wing (clip had broken) and now its seems to be better... not as good as it was but now getting about 45mpg...
    What are the main things to check... from scouting round it appears to be the water temp sensor, the egr valve clean, the mass air sensor & the air intake manifold temp sensor. Is there anything else i should be looking at ?
  8. jimbooboo
    jimbooboo Member
    153
    9
    I'm experiancing the same, but with a 140bhp cabriolet. I think its my cam shaft though.. :/
    Do you hear a weird sort of blowback noise coming from the the intake?
  9. joaopedr
    joaopedr New Member
    10
    Any update? I'm experiencing the same problem with a 2.0 TDI Cabrio with DFP removed.
  10. DieselJake
    DieselJake Well-Known Member
    2,467
    515
    Weather or driving it like a BMW.
  11. joaopedr
    joaopedr New Member
    10
    Even beeing very careful can't get bellow 9,2L/100Km in the city (urban driving).
    Its a 2.0 TDI convertible with automatic gearbox.
