B7 2.0t FSI 4 Wheel Drive System No Electronic Dif!!!
jey Jun 15, 2010
  1. jey
    jey Member
    229
    Just had the car remaped and the guy couldnt put it on the dyno as the car is perment 4x4, he said its the bog standard type of 4x4 ie the front wheels turn and so do the back!
    bit susprised at this on 2006 quattro SE, anyone any thoughts or info theyd like to share??
  2. rowdyboy
    rowdyboy Member
    804
    19
    It's true.
    Even if it had an electronic diff, he would need a 4wd dyno.
  3. goon
    goon Member
    332
    haldex diffs on s3 and tt have given problems (expensive ones) so be thankful its "bog standard" If he didnt dyno it how do you know its264bhp?
  4. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,705
    643
    As above all A3, S3, TT models are haldex, A4/s/rs, A6/s/rs, Q7, A8/s are all permanent 4 wheel drive, I'm surprised the tuner did not know this, it's been like this for over 10 years!
  5. solaris
    solaris Member
    416
    17
    Hi,
    I was facing the same problem IMO torsion diffs are far better. I hate Haldex!...It's possible to drop the drive shaft to dyno on 2 wheels (point less) some garages will be reluctant to do this.
    luckly the garage down the road has a 4wd dyno dynamics roller so i'll be heading that way after my car's been mapped.
  6. p1tse
    p1tse Member
    796
    24
    what remap did you go for?
    i assume the figures were estimate, maf reading calculations from vagcom etc.?
  7. jey
    jey Member
    229
    the figures are an acturate estimate, this model has a fwd version which the tuner has mapped tones of and they all come out no more than 5bhp more or less.
    rowdyboy electronic dif allows u to pull the fuse for either front or rear to disable it so 4wd rollin road isnt needed.
