B6 TDI Avant - Wheel specs - PCD / offset etc
DALE_AVANT Jan 24, 2012
  1. DALE_AVANT
    DALE_AVANT Member Team Brilliant Black Audi A4 Audi A3 Audi Avant Owner Group TDi
    618
    21
    Hi all.
    Query on wheel specs:
    PCD: 5 x 112??
    Ideal Offset: ??
    Sensible rim width and tyre size on 17": ?? (currently 235/45/17, standard B6 A4 Sport alloys, not sure on rim width)
    Sensible rim width and tyre size on 18": ????
  2. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Offset can range from et43 -et35. The lower the number the closer the wheel will sit to the arch
  3. jbcalvin
    jbcalvin Member
    691
    21
    ET 43 is what came from the factory on A4 wheels (not sure about S4/RS4), for 18's I run 235/40/18.......
  4. quattrojames
    14,050
    576
    S4's run ET45.
    "Factory" B6's with 18" wheels were 8J running ET43 on 235/40 rubber.
    As mentioned, ET35 is pretty good unless you're into "poke" and "stance" :wacko:
  5. DALE_AVANT
    618
    21
    Cheers for the replies guys.
    So ET35 would fill the arch a little better (i.e. make the stance wider)?
  6. DALE_AVANT
    618
    21
    So I'm on the lookout for 18's with 235/40/18 tyres............does anyone happen to know how much more these would weigh over 225/40/18 (approx obv.), and how much more full my arches will look on 235's?
  7. rawtor51
    rawtor51 Active Member
    355
    47
    Im running ET42 with 10mm spacers bringing them down to ET32 no problems at all, 235/40/18, check my thread if you want to see how it could look.
  8. StuG808
    StuG808 1.9tdi130 Avant FailWheelDrive
    257
    9
    Getting the ET as close to the manufacturer's spec as possible is best for steering feedback, going with lower ET's changes the scrub radius and the steering feedback lightens and is more prone to kickbacks (although minor in scale). But it does fill the arch more, so it's all about priorities: look over feel.
    Although, I'm saying this coming from a previous car where the standard ET was +45 and was common to fit +0 or minus offset wheels! So it was a bit more of an issue there!
  9. B6Steve
    B6Steve Member
    42
    If you plan on lowering the car substantially then you might want to stick with the slightly higher offset. You can always space it out afterwards if you are wanting that look. The last thing you want to do it get a low offset, lower it loads and find that you have a bit of scrubbage.
