B6 steering wheel swap
andy.l Sep 24, 2013
  1. andy.l
    andy.l Member
    224
    20
    Ok ,I've read through the searches about this. Is it just a case of undoing the battery,then the bolts holding the 4 arm steering wheel on,the plugs behind the wheel and then replace with the 3 arm wheel (complete with correct airbag),its not going to go off in my face or anything is it? There isnt a 'how to' in the guides section?
    thanks
    andy :)
  2. DieselJake
    DieselJake God Mode
    2,209
    400
    Wouldn't worry too much about it blowing off in your face as airbag's are activated from the front of a car. There are many guides plus this question gets asked and answered daily. This isn't exact but it's what two seconds of searching google provided AudiEnthusiasts Steering Wheel Swap.
  3. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    The airbag control module contains a capacitor large enough to fire the airbag (so even if the battery gets disconnected in a crash the airbag can still deploy).
    This is why the advice is always to disconnect the battery and wait a few minutes for the capacitor to discharge - it's all too easy to short a couple of pins when opening the connectors, and if the capacitor is still charged that can set off the airbag.
    Don't take the risk - remove the battery and wait for a few minutes.
  4. andy.l
    andy.l Member
    224
    20
    Thank you
  5. pauldazzle
    pauldazzle Well-Known Member
    1,115
    79
    You'll get an airbag warning light too if you don't disconnect the battery.
