B6 Avant 1.9tdi Quattro - 312 brakes
munchkincoupe May 23, 2012
  1. munchkincoupe
    munchkincoupe Member
    948
    19
    I upgraded the brakes on my A3 with the 312 carriers/discs and was more than happy with them
    I now have a 1.9tdi Quattro Avant B6 - is it just the same upgrade of fitting 312 carriers from the 2.5 / 3.0 to my current calipers and then fit the 312 discs?
  2. gavsman
    gavsman Member
    379
    That should be it, once I fitted Carriers from a 3.0 I put on 312mm discs & pads...that's it.
  3. munchkincoupe
    948
    19
    Would the pads just be the same size though as the actual caliper is unchanged?
  4. gavsman
    gavsman Member
    379
    I think they are the same size as the 288mm pads - but if you are changing discs I would put new pads on.
  5. PhilW
    PhilW Member
    182
    Any part numbers for the carriers?
    Sounds like an upgrade to me next time i change discs and pads. :)
  6. gavsman
    gavsman Member
    379
    part code is: 4B0615125C
    PhilW likes this.
  7. quattrojames
    14,050
    576
    I always thought quattro models came with 312mm front brakes already?
  8. Captainwow
    Captainwow Member
    39
    Sorry to jump in. So, if I want to upgrade to 312s, I don't need to change the caliper? Just the carriers (and discs, obviously)?
    I've got a 2004 1.9TDI 2wd
  9. yendall24
    yendall24 Member
    571
    hi all my car is an a4 1.9tdi sport on an 04 i did this upgrade when i first bought the car all you need is the larger carrier bracket you keep the same calipers and pads . makes a massive difference
  10. ASHIHARA
    ASHIHARA Member
    294
    15
    No,they dont;mine was 288m.Actually depends which engine you have,like 1,8t 190bhp ,2,5tdi 180bhp , 3,0.
    For 312mm setup,u need the cariers and discs,calipers and pads are the same.
  11. scott b
    scott b Active Member VCDS Map User
    1,254
    if your using A3 callipers then youll need to botch the brake lines (plastic piping and cable tie it to the strut, ill be changing the calipers to the 3.0l v6 tdi ones along with the lines discs are the same, but check that the pads have 2 pad low warning sensors
  12. munchkincoupe
    948
    19
    Will the 3.0 petrol Cabrio B6 have 312 brakes as standard too?
  13. bugwhizz
    bugwhizz Member
    144
    yes
  14. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,196
    160
    I was never too happy with the 312's :(
