b6 avant 1.9tdi exhaust mod
bradster Mar 11, 2011
  1. bradster
    bradster Member
    37
    Some help please iv e got audi a4 avant b6 1.9tdi FWD, i was thing of fitting cat back 1.8turbo twin outlet exhaust to make it look more beef,Dose it fit straight on and dose b7 also fit b6 , iam trying to locate a used one but not having much luck.bradster[​IMG]
  2. quattrojames
    14,050
    573
    B6 and B7 are both compatible, just be aware that you need to fit fwd to fwd and quattro to quattro as the two aren't compatible.
    So you'll need a 1.8T fwd system, or a 2.0T from the B7.
  3. Garfie
    Garfie Member
    179
    Also make sure you pick up another rear box hanger bracket and bolts and ideally also another heat shield and speed nuts to fit it.
  4. p1tse
    p1tse Member
    796
    24
    but what happens to the rear valance?
  5. swarcup
    swarcup Well-Known Member
    1,326
    40
    that needs chaning to the one from the 1.8t also. just remember that saloon only fits saloon, avant only fits avant and the cab just wont fit iether of the other two.
  6. p1tse
    p1tse Member
    796
    24
    is the bumper split into two with a interchangeable valance then?
  7. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,884
    182
    yes it's in two parts, you will need a new rear valance with twin cutouts, part number 8E9 807 521 G GRU £166 INC VAT, that is the s-line one you can fit a non s-line one from earlier models and from memory that is about £80 ISH but it all depends on what front bumper you have to match them up.
  8. Garfie
    Garfie Member
    179
    Or the other option is to go for the Votex kit which is what I did.
  9. Max M4X WW
    Max M4X WW Member
    139
    Sorry for the bump, but would the following be compatible?
    Car: B6 1.9 TDi 130 FWD
    Exhaust: B7 2.0 TDi 170 Twin Exit FWD (Pointy down tips!)
    Valance: 'Ultra Sport'
