B6 A4 OBD, OBD II, CAN BUS???
Higgsy Sep 28, 2010
  1. Higgsy
    Higgsy Hard To Spin
    96
    Hi all
    I know this has probably been talked about more than the weather, but even using the search facility i cant seem to find what type of cable i need to plug into my 04' 190 S line Q Avant? is it OBD, OBD II OR CAN BUS? :think: Im not sure and would definitely appreciate any input.
    Cheers in advance
    Higgsy
  2. AU01 A4
    AU01 A4 Member
    211
    obd II I think, thats whats on say on cable mine, but some one will be along to comfirm
  3. Broken Byzan
    13,237
    466
    both OBD2 and CAN bus are apropriate on this model
  4. Ryanmt
    Ryanmt Member
    103
    vag com 409 is what you want.
  5. Higgsy
    Higgsy Hard To Spin
    96
    i think ive got vagcom 409 so hopefully with my new found gen i should be sorted, thanks alot all!!
  6. fourcircle
    fourcircle nj
    944
    32
    What is it you want to do with the cable mate? If it's just diagnostic codes then vagcom 409 (the free trial version available on the ross-tech website and compatible with el cheapo ebay cables) will do the job. If you want to do more than that you'll want a newer version of vagcom or a handheld unit.
    cheers
    nj
