B5 Towbar needed urgently
volvo1980 May 11, 2011
  1. volvo1980
    volvo1980 Member
    51
    I'm in need of a A4 b5 towbar sharpish, either a swan neck or detachable one. Going camping next month so need it for the trailer!
    I know this should be in the wanted section but just wanted to give you b5 owners a nudge.
  2. volvo1980
    volvo1980 Member
    51
    Come on! Somebody must have one lying around in there garage!
  3. I bough a Westfalia from 'towbarman01' on eBay, fitted last year, MUCH cheaper than anywhere else, everything you need, all you need is someone to fit it. This depends on available funds of course, but he will have the bar to you in a day, you will get 13pin electrics on that bar only, you will need to get the 13 pin to 2x7 pin adapter, it is a lead around 12" long, you will also need split charge relay, and indicator relay/beeper thing. There is a Westfalia adapter available, takes the 13 pin down to a single outlet 7pin for towing a trailer as opposed to a caravan, it is about 2" long, and simply changes the socket available, plugs into the 13 pin.
  4. volvo1980
    volvo1980 Member
    51
    yeah cheers for the advice, if nothing second hand turns up i will have to buy a new one!
  5. stoop44rio
    stoop44rio Member
    76
    Ive two here but im in Belfast so the postage probably will be a killer!!
  6. volvo1980
    volvo1980 Member
    51
    Are either the detatchable type?
  7. stoop44rio
    stoop44rio Member
    76
    I think they're both the detactable type iirc, I'll try to pm you a pic tomorrow.
  8. volvo1980
    volvo1980 Member
    51
    Or send it direct to my email alex_dearden@msn.com
  9. volvo1980
    volvo1980 Member
    51
    Still need one!
  10. volvo1980
    volvo1980 Member
    51
    Well I have got a detachable towbar off eBay for my 2001 avant but I am just after a but of wiring advice, does anybody have a wiring diagram for single electrics and do I need a bypass relay?
  11. Seriously, I would get an auto electrician to fit it, mine cost £75 to get fully fitted, bolted up and wired, worth every penny to me.
