B5 TIP Fitted - with pics
The Doctor Aug 15, 2012
  1. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Well, today I had a day off work and finally got round to fitting my B5 TIP, which I bought unused from Fran-S3 ages ago! It's a v1 TIP, so it's the multi-piece version. I took some pictures of the installation in case it helps anyone else. The v2/v3 installation will be simpler because of the 1-piece construction of the TIP.
    Engine bay prior to installation, with the OEM TIP but with my Saikou Michi catch can visible just under the strut brace:
    First, I smoothed off the internal edges of the aluminium section of the TIP where the various pipes join the main body, more to satisfy my OCD tendencies than anything else.
    Next I removed the engine cover, battery cover, and airbox. I also removed the standard air duct to the airbox, which is fed from the off-side front wheel arch. This is just held on with 1 nut in the engine bay:
    Then I un-plumbed the various connections into the original TIP. Luckily I had already replaced most of the 1-use Audi hose clips with Jubilee versions, so this was relatively straightforward and painless. Finally, I removed undid the jubilee clip holding the original TIP to the turbo itself, and removed the TIP, leaving this:
    Original TIP was actually in perfect condition:
    Turbo hiding away at the back of the engine:
    Quick check of the turbo and all looks healthy, vanes spin nice & free:
    Next for the installation of the aluminium adapter. Mine is the original version with 2 2mm grub screws. First, I applied a bead of Loctite 5920 Premium Silicone Copper Gasket Sealant (rated to 350 deg C, available from Halfrauds for a fiver) around the inside of the adapter, and also into each of the grub screw threads to ensure an air-tight seal once installed. You only need a thin bead; in the picture below I've used a bit too much, but I wanted to ensure a good seal:
    Next, with the adapter installed onto the turbo (it's a snug fit, so wiggle/twist it to get it on, DON'T force it), I wiped the excess sealant away, being very careful not to get any on the turbo vanes:
    With the grub screws at the 2 and 4 o'clock positions, I nipped them up and attached the first part of the TIP onto the adapter. I positioned the head of the jubilee clip towards the rear of the engine bay for easiest access. You'll need a 7mm socket and small ratchet to tighten the jubilee around the TIP to hold it tight on the adapter:
    I must admit that I then spent quite some time fine-tuning the routing of the various pipes & hoses around the new TIP to ensure a neat installation, and after re-fitting all connections to the main aluminium element of the TIP, ended up with this, which I was pretty pleased with:
    I decided to spray the aluminium heat shield / filter mount with Halfrauds crinkle black paint so that it blended into the engine bay:
    Finally, after fitting the remaining 90 degree bend and Jetex filter and replacing the engine covers, I ended up with this:
    Very pleased with the installation, and the way the car drives. Hope the pictures are useful to anyone else planning this installation.
  2. mcpickering
    mcpickering Member
    136
    how have you found the difference from standard TIP/air filter. in terms of noise/performance and responsiveness?
    very nice clean engine bay btw :)
  3. badger5
    9,398
    1,943
    neat
  4. Prawn
    11,407
    3,288
    Very neat, nice to see a perfectionist at work :)
    How does it feel now? Any data logs to see it's worth?
    Despite all the obvious changes and evolutions, the V1 is still an excellent product, and it's the one that kicked off and got the whole ball rolling again for ko4 tuning!
  5. superkarl
    superkarl MAN OF STEEL
    9,398
    2,376
    That's an engine bay tuffty would be proud of!
    Nice work
  6. jojo
    28,846
    3,508
    Good work Paul!
    Just one thing though, is that oil running down the side of your engine below? Check your half moons and rocker cover gasket.
    s33nyboy12 likes this.
  7. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,233
    380
    Tidy install, spraying the heat shield black has made a lot of difference to how it looks.
  8. Hammy999
    Hammy999 Member
    175
    Very neat looking bay, the heat shield matches in well.
  9. WillJP
    WillJP Member
    Look good! very tidy :)
  10. badger5
    9,398
    1,943
    apart from the oil smeg down the side of the engine..
    that would not be tolerated in tuffty land
  11. <tuffty/>
    20,881
    3,701
    He knows me so well :D
  12. The Doctor
    1,394
    189
    Don't worry chaps, that's gone now. I knew I should have taken the pic after and not before cleaning it off!
    JoJo - I'll be keeping an eye on it now it's cleaned up to make sure it's not returning. There's no obvious leak, so hopefully it's just built up over the years.
    Just one question from the install - the front corner of the heat shield touches the sound proofing on the inside of the bonnet when it's closed. Is that right? Ideally it could be 5-10mm lower so it doesn't come into contact, but I can't see any way of lowering it down.
  13. <tuffty/>
    20,881
    3,701
    I believe the point is that it 'seals' to prevent the ingress of heat... thus contributing to the 'shield' part of the product :D
  14. The Doctor
    1,394
    189
    Yeah, I had considered that was the point, but wanted to check. If so then I'll stop fretting about it!
  15. The Doctor
    1,394
    189
    Wow, just been out for a bit of a longer drive this morning. What a difference! Sounds much more throaty/growly around 2-3k rpm, you can really hear the engine breathing now, and it pulls so much stronger above 5k rpm. Fantastic.
  16. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    nice work mate and tidy bay.
  17. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,120
    353
    Schweet work Doc! Tidy as always!
    Whats next in the pipe line!?
  18. The Doctor
    1,394
    189
    Hi Jay, good to hear from you. Hope your hay fever has calmed down since I last saw you!
    Not sure what's next mate, there's always a lot on the list! Need to get some spacers for the new rims really, but the kids are spending all my money as usual! Hopefully Santa will bring me a DA polisher this year (I have been good) so I can really go to town on the shine!
  19. Jay A3
    2,120
    353
    Definitely calmed down, turns out I was also sun burnt! The last never goes away, if anything it just keeps growing...what size spacer are you thinking? Didn't see you at aitp!
  20. The Doctor
    1,394
    189
    No, wasn't at AITP in the end, because we took our 2 girls to Mum & Dad's to stay for the week. Shame, it looked like a cracking club stand.
    Anyway, was thinking the usual 10mm front / 15mm rear spacer combination. But as I say, there's a lot on the list. Also want to drop the sump & check/clear out the oil pick-up at some point for peace of mind. Jobs, jobs, jobs...
  21. carl-1968
    carl-1968 A4 sold, lots of bits available, ask for details
    538
    30
    tidy work
  22. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    195
    Good write up. And yeh you should of put pics of clean engine! Lol too many of us have OCD.
    Question... How do you find with the jetex? I found it better with standard air box and b5 tip and I preferred the sound!
    Cheers, Sean
  23. The Doctor
    1,394
    189
    Jetex is great. Obviously much more noticable air intake/dumping noise when on & off the throttle vs OEM set-up, but so far so good.
