B5 S4 rough idle
S4_Biturb Mar 3, 2012
  1. S4_Biturb
    S4_Biturb New Member
    23
    Hi all, as per title, my S4's still idling rough. I had her put on a diagnostics machine week, which came up with an airbag fault (getting done next week) and a lambda sensor fault. I've have the lambda sensor changed and it has improved alot, but its still rough. Mainly when its settled down to around 8-900 revs. I changed the plugs yesterday to ngk platinum laser ones, and again it feels a little better but still not perfect. Im assuming its an air/vacuum leak i.e maf sensor, but any help is much appreciated.
  2. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,271
    611
    always been like this? is it std?
  3. murran
    murran Well-Known Member
    1,545
    39
    what bank was the lambda fault on? did you look at the plugs when you changed them? any black/burned out plugs on the same bank?
    might be wise to have a comp test test done. see if anything correlating...........
  4. ldoshiv2
    ldoshiv2 Member
    82
    maybe coolant temp sensor ?
