B5 S4 FRONT BRAKE CONVERSION
marktdisport Jul 18, 2012
  1. marktdisport
    marktdisport Active Member
    1,195
    15
    So from a previous thread about brakes made me wanna spend some ££ so i got hold of a set of s4 callipers from a T reg 2.7 S4.. so just searching for brake conversions then just came across alex asking a question about pre facelift to facelift callipers being different does this make any difference at all ?? just worried its not a bolt on part etc just wanna bolt them on and go if you get my drift ?? also do the clear the Sline (RS6) style wheels ok (genuine et43).. any pics of done conversion would be great thanks mark
  2. bowen
    bowen Member
    466
    20
    Hi Mark,
    I have calipers sitting in my spare room, need to get my ass in to gear. Not to sure about the facelift question, i believe it is just a bolt on upgrade?
    Regarding ET; To clear the calipers,you need ET39, soif your wheels have ET42,you need 3mm wheel spacers: 42-3=39
    Cobra88 likes this.
  3. marktdisport
    1,195
    15
    Just reading ASHIHARA thread bowen and just noticed he's done said upgrade with my wheels but no mention of spacers but hopefully someone who has done the mod can confirm..... thanks for reply
  4. ASHIHARA
    ASHIHARA Member
    294
    15
    I have 6mm wheel spacers;my wheels are replicas RS6 with ET45.To clear calipers you need ET 39,like @bowen said.
    It`s true,there is 2 type B5 S4 calipers,they have the same discs,but the pads are slightly different.
  5. marktdisport
    1,195
    15
    Thanks for the reply ive also asked the question in your build project m8.... thats a shame as didnt really want to go spacer route but if i have no choice ill have to invest... They are of a pre face lift T reg s4 thanks mark
  6. ASHIHARA
    ASHIHARA Member
    294
    15
    I didnt want aswell to put spacers in the front,but it was the only option to clear the calipers.
    Imagine what surprize was for me when i saw they dont fit without spacers!I dont understand what is different between S4 B5 and A4 B6,because S4 B5 17inch wheels have ET45! :blink: :uhm:
  7. marktdisport
    1,195
    15
    yeah this is were im getting stuck to understand because the car ive brought them of as the std avus 17 on still... so why wont they fit is bugging me... just looking at th fk range on dpm performance they also come with longer bolts for 2 sets is 90 + vat + 10 pp so not to bad...
  8. ASHIHARA
    ASHIHARA Member
    294
    15
    If u find out the diferences and why we need spacers,let me know;is a total mystery for me :confused:
  9. bowen
    bowen Member
    466
    20
    Have you checked out GNJ TPI spacer they come with bolts and are cheaper.
    My calipers look like the have 4 pads per caliper, if that makes sense?
  10. ASHIHARA
    ASHIHARA Member
    294
    15
    Bouth of them have 4pads per caliper,the diference is the pads have slightly different shape.
    I paid for my bolts and spacers front and rear like 40-45£ from ebay.
  11. marktdisport
    1,195
    15
    right is the any part number experts around !! been told today that the B7 3.0 tdi Q has also got the same brakes as a S4 ??? so i had a nose on ebay and they do look very big brakes on the pictures but was wondering if anyone with etka can cross reference the part numbers of the callipers etc........ the strange thing is these also come with thw 18" s line alloys
  12. ASHIHARA
    ASHIHARA Member
    294
    15
    Like i have explain to you on the PM,they are totally diferent calipers(and pads),but with the same size of brake discs 320mm.
  13. adamss24
    adamss24 Well-Known Member
    4,551
    392
    The prefacelift s4 has the Lucas HP1 calipers with 4 pads per side and will fit under the Avus 17" wheels as they have a shallow spoke design. The facelift s4/allroad (2002 on) and the 3.0 tdi b7 a4 uses the HP2 caliper which is made by ATE, it uses twin pads per side and it's a much better caliper... They will also fit under certain 17" alloys (allroad comes with 17" wheels ET25) and 18" wheels on the b7 with sport suspension.
  14. ASHIHARA
    ASHIHARA Member
    294
    15
    Mine are Lucas calipers prefacelift and do not fit ET 45 wheels without wheel spacers.
    I have seen allrouds whit the same calipers like mine,but i dont know what year.
    Lucas calipers have 2type of pads,but the same 4pads per caliper.
  15. marktdisport
    1,195
    15
    Well they come today and they are massive but Ive gotta get spacers disks and pads before fitting them.....they also need a damm good clean up
  16. adamss24
    4,551
    392
    Early w reg allroad have the HP1 brakes and later 51 reg on have the HP2 caliper made by ATE. Much better brakes and wider choice of pads on the later model ! I have 2 allroads: 1 pre facelift and the other a 2004 model- both are 180Bhp. I actually changed the brakes on the early model as they were not adequate for the size of the car ! I fitted rs4 b7 8 pot brembo brakes and they are as good as they look !
  17. marktdisport
    1,195
    15
    These callipers will be up for sale now just brought some 2003 b6 s4 callipers disks back plates etc
  18. marktdisport
    1,195
    15
    Well today I fitted my b6 s4 brakes.. Well impressed with the sheer power of them over my tiny standards lol...and I didn't even need spacers which was the reason for buying a b6 set up... As the b5 set up I would of needed at least 5mm spacers and I didn't want it any wider with the mrs driving by kerbs so more expense.....Happy days and well worth mod
  19. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Great stuff, I totally agree with you with regards to the B5 S4 set up, I had after market wheel's and had a nightmare with fitting.
  20. ASHIHARA
    ASHIHARA Member
    294
    15
    I decide to change my S4 B5 front calipers with A4 B7 2,0TFIS calipers;does anyone know if i can use the same discs(both calipers use 320mm discs) with B7 calipers?
    I looked on eurocar parts and they look the same brake discs...
  21. Andi25th
    Andi25th Member
    227
    17
    Can someone make a Brake upgrade how to. Or just a S4 upgrade how to.
  22. marktdisport
    1,195
    15
    I believe so m8... I looked on a few eBay adds and they have the dimensions so I don't see why not....
  23. marktdisport
    1,195
    15
    If my damm I pad would upload pictures I'd of gladly done one... But for some reason it's a pain in the a**
    I brought a set of huge s4 b5 callipers from a 1999.. For around £70 but with talking to a few people on here... I found out you need to run spacers to clear the brake callipers with the wheels, I suspect some aftermarket wheels would clear them but never the less I didn't want to use spacers as the misses drives mine a lot and being any wider I'd assume I'd have no rims left so for me it was a no no... I then found a set of a v8 2003 s4 callipers which to look at there a lot neater and bigger callipers through the wheels only trouble is there rare find and bloody expensive I payed 350 for the set up to be fair the disks and pads are nearly new probably covered 1000 miles....so I didn't mind paying that... When they was delivered I was like a kid in a sweet shop. Couldn't resist but to get them on. Real easy and simple job for anyone really I'm a ex fitter so took me about 1 1/2 hr ish... With fitted the brakes and bleeding them up..the road test was brill response I thought my std ones was ok for the size of a weight of she a4 but now there a different league... If money is no object you best to get the b7 2.0tsfi 320mm or s4 b6 or have told all 3.0tdi as well... I have my old callipers to get rid of but I didn't want spacers if your already running spacers then a cheaper brake upgrade is the b5 set up.. Hope this helps you choose your upgrade
  24. ASHIHARA
    ASHIHARA Member
    294
    15
    My new big boys ;)
    rear calipers with 288mm solid discs
    front calipers with 320mm vented discs
  25. marktdisport
    1,195
    15
    Nice 1 m8 they look very similar to mine... What are the rears off.....
  26. ASHIHARA
    ASHIHARA Member
    294
    15
    I don`t understand...:think:
  27. quattrojames
    14,045
    570
    What car are the rear calipers from?
  28. ASHIHARA
    ASHIHARA Member
    294
    15
    Aaaa,k :) ;bouth of them(front and rear) are from A4 B7 2,0TFSI.
  29. marktdisport
    1,195
    15
    Sorry m8 I should of asked the question better...
  30. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,461
    199
    Are these the same as the B6 S4 4.2 callipers? - I was originally planning to fit a set of RS4 brakes but due to costs of discs.etc it seems abit overkill for a 2.5TDi.
    I am now hunting a set of B6 S4 calipers...
  31. marktdisport
    1,195
    15
    Yeah that's what I've just fitted 2004 s4 4.2 bit overkill on cost but cheaper than front bumper wings and headlights lol....
  32. AlexGSi2000
    1,461
    199
    Good stuff - im taking it they were just bolt on jobbies?
  33. marktdisport
    1,195
    15
    Yes m8, straight fit and no spacers required...
  34. AlexGSi2000
    1,461
    199
    Cool, where did you get em from? Ones I have found so far are quite expensive.
  35. SmoothAssault
    SmoothAssault Will design for mods
    822
    53
    I think I have some B5 RS4 carriers knocking about somewhere, any chance they're the same size you need?
  36. marktdisport
    1,195
    15
    Yes I payed through the nose for these of a car with no rear end.... Just found one breaking I I'd put a link up in the eBay add for another one breaking with front and rear accident damage... I've got a set of b5 callipers also now spare but these need spacer to fit under the wheels....
  37. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,169
    148
    Nooo not over kill! Perfect. I love having 345mm up front.
  38. marktdisport
    1,195
    15
    Lol still looks strange a 1.9 tdi with some big stoppers up front... Need bigger rears now...
  39. AudiLeon
    2,169
    148
    I keep thinking that too. I'm big up front but hard anything on my rear :)
  40. marktdisport
    1,195
    15
    I might have a look around... More money
