B5 S4 FMIC + Rad being done this week
AndyC May 8, 2011
  1. AndyC
    AndyC Moderator Staff Member Moderator
    719
    Hey guys.
    Thought I would pop up the latest project for the S4
    Just gone to Pace for kit development:
    FMIC
    Radiator
    Gear oil cooler
    not sure yet how its going to be done, however its going to be a high quality core with and well made.
    our previous testing with Pace intercoolers on the Renault range has proved time after time that Pace intercoolers are excellent and have exceeded other manufactures that are well known.
    The pricing is yet to be decided, but its going to be competitive with consideration to the quality.
    Pics when I have them.
    if anyone is interested themselves let me know
    andy
  2. Nez
    Nez Member
    598
    when you get it please do post some pictures....
  3. AndyC
    719
    should be end of next week....
  4. Nez
    Nez Member
    598
    Cool thx :)
  5. dest
    dest Member
    193
    Will the fmic be a similar design to the 2 in, 2 out CX racing one, or their newer 2 in, 1 out?
  6. Oranoco
    Oranoco Well-Known Member
    3,973
    405
    Their intercoolers are very god generally. My track Escort has one of the very first full wicth intercoolers they made and despit ebeing a pre production example it's excellent and more than delivers what it needs to
  7. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    What are you going to do for an oil cooler? Will your radiator use the OEM heat exchanger or will you be going with an off the shelf dedicated unit?
  8. AndyC
    719
    I will let you know when I have spoken to Pace later
  9. AndyC
    719
    some tasters..
    core sizing......
  10. jamie226bhp
    jamie226bhp Member
    468
    Dont think you'll have much of the metal left behind the bumper by the time you've fitted that lol
  11. AndyC
    719
    it will indeed be modded....... but the core size of the side mounts is poor in comparison....
    Pace have done ALOT of testing
  12. jamie226bhp
    jamie226bhp Member
    468
    I know I had to cut almost all of mine out to just the flat section in the middle to get mine fitted but like u say the standard one is ****
  13. aragorn
    18,490
    855
    It looks a bit small to me. Myabe its just perspective and scale, but people put coolers that size on 1.8T's...
    The CX Racing twin pass cooler that lots of people use looks both taller and thicker.
  14. jamie226bhp
    jamie226bhp Member
    468
    I thought it was on a 1.8 t as it doesn't look that much bigger than mine but then again pace cores are meant to be really good
  15. AndyC
    719
    they make them in house as well, which is rare
  16. AndyC
    719
  17. aragorn
    18,490
    855
    nommy!
    Whats the boost sensor from?
  18. AndyC
    719
    stock one
  19. aragorn
    18,490
    855
    ah fair enough, thaught the stock one was held in with a jubilee clip!
  20. AndyC
    719
    I havnt seen the car, but I havnt changed it and I doubt they have?!?!?
  21. Blue_Thunder
    1,776
    33
    You're both right! It is the stock sensor, and it does attach to a stock TBB with a jubilee clip.
    However, on an APR bipipe like mine, or a fancy custom jobbie like Andy's, you are able to use the holes in the sensor to fit some bolts through. Guess it's probably a generic MAP sensor that is used in other applications which have it screwed in place. The fitment on a stock S4 was a bit of a bodge job by Audi!
  22. AndyC
    719
    This is part of the kit they will be suppling for the FMIC, complete replacement pipe run etc.
  23. AndyC
    719
  24. aragorn
    18,490
    855
    looking tasty!
  25. AndyC
    719
    the idea being that all the OE fittings and sensors and PAS cooler etc are retained (bar the fan of course)
    easy to fit as well, with as little cutting as possible..
  26. AndyC
    719
    got it back!! ------ looks really good..... :)
  27. AndyC
    719
    The kit is available in three parts..:
    Intercooler and Fan kit
    Pipework
    Inlet Plenum
  28. AndyC
    719
    The core is important as its the strengthened type that is extruded and has internal section that stops the cores ballooning
  29. AndyC
    719
  30. Lee Goodall
    Lee Goodall Active Member
    2,279
    Very tidy, looks brilliant :drool:
  31. CraigG
    CraigG Member
    190
    how much..?
    looks a zillion times better than the CXracing/JHM/MRC cooler, if not a little bit smaller
  32. AndyC
    719
    IIRC
    Cooler and Fan assembly £455
    Pipework £295
    Inlet Plenum £60
    this means you can do your own pipes if you want
  33. camouflage
    camouflage New Member
    12
    That looks a really nice set up with some nice touches. how much bumper cutting is required to fit this kit?
  34. AndyC
    719
    Very little bumper cutting is required
  35. GSiiiii
    GSiiiii New Member
    hi andy do you know the bore of the pipe work used ?
    cheers
  36. JS4
    JS4 New Member
    23
    That looks superb, If you don't mind, how much was it including fitting?
  37. AndyC
    719
    Prices are
    £455 for the IC and Fan assembly
    £295 for the Pipe runs
    £60 for the inlet plenum
    fitting I dont know as it was the development car.
    I expect it takes about 4 hrs
    Andy
  38. GSiiiii
    GSiiiii New Member
    cheers
  39. AndyC
    719
    tbh I dont, but I know it was supposed to be larger in x section than the original pipes
  40. AndyC
    719
    After a few months with this the temps are much faster to drop after heat soak. It's also lower than stock. I will put up the details next week.
    However I am delighted twith the kit
