B5 S4 Cambelt Parts
AndyC Oct 19, 2011
  1. AndyC
    AndyC Moderator Moderator
    719
    Hi Guys
    Has anyone got the part numbers for all the cambelt change parts
    Belt
    Roller
    W/Pump
    Tensioer
    Hydraulic Tensioner
    etc
    etc
    cheers v. Much
    A.
  2. aragorn
    18,579
    868
    Contitech do it kit with everything.
    All German Parts will sort you out.
  3. AndyC
    719
    the reason I ask is that GSF couldnt find the tensioners... (believe it or not)
  4. aragorn
    18,579
    868
    Conti CT920K2
    Comes with the belt, both rollers, hydro tensioner thing, and the relay arm.
    All parts are as per OEM fitment, ie INA rollers and NTN hydraulic tensioner.
  5. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    Does it come with the Thermostat and Water Pump?
  6. aragorn
    18,579
    868
    No, its just a timing belt kit.
    All German will sort you out with the other bits though.
    AFAIK the belt kit, stat and waterpump was less from All German than the belt kit alone from ECP.
