B5 RS4 Engine Problems
Danny Cawsey Mar 11, 2014
  1. Danny Cawsey
    Danny Cawsey Cawsey
    516
    Hi, I'm an 8l S3 owner so not normally over this side but my boss has a 2000 b5 rs4 with a few problems and need some help diagnosing whats wrong with it.
    I took it for a drive today and its got a bit of a lumpy idle doesn't really settle. when on boost its got a very slight stutter and doesn't pull so smooth.
    He recently blew the turbos and has just had two brand new one's fitted a couple weeks ago not sure if this could be anything to do with it?.
    Anyway i checked for fault codes and here is what i got:
    16730 Camshaft position sensor
    16730 Engine speed sensor
    17930 Camshaft adjustment bank 2
    18010 Power supply b+ terminal 30, voltage too low
    Any Help would be much appreciated.
    Thanks, Danny
  2. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Try clearing the fault codes and see which ones come back - some of those may be historical from before the recent work.
  3. Jedgar
    Jedgar New Member
    Try Audi SRS forum they will point you in the right direction
  4. MartayMcFly
    MartayMcFly Booooooost Regional Rep VCDS Map User Gold Supporter
    2,749
    352
    Yup, audisrs is the 'go-to' for B5s
  5. Aeron
    Aeron New Member
    Hi, I'm new to this but I have had three B5's and I'm not planning on getting rid of my present one which has been in my possession
    for the last seven years. I can tell you I had the same problem with the stutter it too run lumpy, I took it to Doug at MRC, and it turned out to be a Cam sensor.
