B5 prefacelift & facelift interior compatability?
gmx Sep 1, 2009
  1. gmx
    gmx Member
    148
    Will the ignition cowling, glovebox, knee bolster from a prefacelift car fit facelift?
  2. Broken Byzan
    13,237
    465
    ignition cowling will, glovebox will as long as you don't have a disable switch for the airbag in there, and the knee bolster won't have the headlight height adjuster on it, or even a slot to put one. I went the Other way no problems
  3. aragorn
    18,373
    829
    Knee bolster on a facelift car contains the knob for the headlight adjustment, its on the dash on prefacelift cars.
    Everything else will probably fit i would think.
  4. gmx
    gmx Member
    148
    thanks guys.
    I think the headlight adjuster must be eurospec thing. Can't see anything like that nor heard of one on B5s here.
  5. docurley
    4,071
    85
    Ah you must have self levelling.
  6. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    you have zenons? as Doc says self levelling..... comes with zenons
  7. olds_kool
    olds_kool Active Member VCDS Map User
    1,089
    13
    id noticed when researching facelift dash conversion that there was no mention of the adjuster switch on american forums, they must not have them?
