b5 lowering springs.b5
hewy Jun 22, 2012
  1. hewy
    hewy New Member
    22
    Hi, ihave a standard 99 plate 1.9 tdi se b5 it is de badged with 18" RS4s , I want to lower it by 40mm but with funds tight was wondering if I could put the lowering springs on the standard shocks, it sits like a monster truck at the minute ( can get my fist between tyre and arch ), heard people say they work with no probs and others say shocks can bottom out , doesn't get driven hard round corners ( just fast in a straight line) , anyone with any knowledge or experience of doing this would be great to get some sound advice , like I said funds tight and don't want rock hard ride of cheap coilovers as have two sprogs in the back a lot of the time.. thanks guys , I'm sure u get bored of being asked this question . would 40 mm be noticable. ??
  2. hewy
    hewy New Member
    22
    Anyone. ????
  3. Mackers
    Mackers Member
    291
    i've dropped my 5.5 2.5tdi avant 30mm on 18" RS4's (look for me add in parts for sale to see who it sits) with NO problems. :D
  4. aragorn
    18,579
    868
    You'll get away with it for a while.
    The stiffer springs mean the shocks have to work harder, and given they're 13 years old and likely somewhat past it anyway, they're likely to die in the near future anyway, if they havent already.
    You shouldnt bottom out with a 40mm drop, even full lowering kits on 40mm springs will come with stock length dampers.
  5. hewy
    hewy New Member
    22
    Thanks 4 that Aragorn , will get some and can always get shocks after ( will all shocks fit all springs if for the same vehicle ?? ). Also Mackers , did u say the silver avant with rs4 s on had been dropped 30mm , is it already lower as standard or was it se height , ie normal height not s line height if that makes sense, , looks well low for 30 mm. : ). Thanks guys. ..
  6. Mackers
    Mackers Member
    291
    mine was on sports suspension ( i think about 10-15mm lower than STD..... i'm sure someone will confirm)
  7. hewy
    hewy New Member
    22
    Thought so. : ). Does any way know if I would have to change anything else like bump stops or anything else if just putting springs on , or would I be nest putting cheap set of coilovers and springs on , , also what's the difference between COILOVERS AND SHOCKS. , thanks again guys .
  8. Mackers
    Mackers Member
    291
    i did my bumpstops as it was all apart anyways, altho the old ones looked and felt ok and not too old really, the shocks looked kinda new too and dry, i'm still to experiance my car bottom out as yet, even with the 2.5 in the front and about 90KG of wood, wires and "install" in the boot.
