B5 Immobiliser fault. This guy can solve the problem
Mr.T Mar 3, 2012
  1. Mr.T
    Mr.T New Member
  2. Broken Byzan
    13,237
    465
    Problem is it's not cheap, it's around £70 to have the .5p chip removed and reflashed with the correct 24c02 flash. I did my own on my last car/tune but struggled with the de soldering. The Flasher and blank chips only costed sub £15 iirc
  3. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    Cheap eBay hot air solder station :) used to have one and it desolders SMD stuff so easily...
  4. _JMills
    _JMills Member
    41
    :O
    I need this done to mine, stupid immobiliser needs to be burnt :(
  5. Mr.T
    Mr.T New Member
    Well if you need it done, let me know and i'll forward you his details
  6. _JMills
    _JMills Member
    41
    Yeah if you could, hopefully this might work, all my car manages to do now is start, run for 2 seconds then the fuel pump gets cut and the engine stops really didn't realise how much I hate immobilisers!
  7. Mr.T
    Mr.T New Member
    I had the same problem, tried everything! This was the only way to solve it.
  8. aragorn
    18,579
    868
    I'm sure disabling the immo wasnt the only way to solve it, fixing whatever was wrong with it would have solved it too!
  9. Broken Byzan
    13,237
    465
    Really, linky?
  10. Mr.T
    Mr.T New Member
    Agreed, but its the money it costs to solve it! I spent alot of money on parts after following a walk through on here to no reult.
