B5 engine mount on b6 1.9 tdi
glenandem Oct 1, 2013
  1. glenandem
    glenandem Active Member
    674
    31
    Anyone replaced the drivers engine mount on they're b6 a4 with a b5 s4 mount, seen some febi ones on eBay for £30 as opposed to £90 for the correct part no one from tps, I only have the passenger side which has the sensor on and have read on other forums that some guys have replaced they're b6 mounts with b5 s4 mounts as they think they're slightly stiffer, I'm only looking to fit one of these as they're cheaper!
  2. DieselJake
    DieselJake God Mode
    2,212
    402
    Fairly sure they're the same across the b6/b7/b8 range, either way best to go aftermarket with the amount of mount's not holding up... maybe it's wear and tear but there's been a fair few broken (mine included) but surely you'd expect them to last the life of the car.
  3. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,643
    623
    All depends on what you classify as the life of a car. (I'm sure I read that audi say the life of a car is 10 years and 200K miles) on one of my B5's I replaced the mounts after 13 years & 270K, but I've seen them go on cars with less than 100K. I guess it's all down to the manufacture who made the mount and if they were cutting corners to keep the costs down, and the guy who made the mount, was it a Friday afternoon special.
    Northampton_ofn likes this.
  4. glenandem
    674
    31
    yeah mine looks original but has the purple ooze at the bottom of it!
    ive replaced the ns due to giving the fault code they give but the os doesnt have the sensor in and ive read that alot of people replace them with the 034 or b5 s4 mounts so im gonna fit the s4 mount as theyre quite cheap on ebay and theyre febi ones which are supposed to be ok.
  5. Google44
    Google44 Member
    33
    I've replaced mine with B5 rubber of standard A4 saloon. They fit fine.
  6. glenandem
    674
    31
    yup your right, I recieved it in the post this morning and went straight out to fit it, very easy to do took about ten mins to do!
    took me much longer replacing the anti roll bar links I had!
    definately feels less movement in gearstick now and when I use to rev the engine you could feel it rock the car, now it's hardly noticeable!
    just need to take it on mway now see if its done anything for my vibration issue?
  7. jake cass
    jake cass A4 b6 AVF running a BV43 SRE clutch S4 BBK Audi A4 Team Akoya TDi saloon
    33
    Did you notice any unwanted rattle/excessive vibration at idle? I am in urgent need to new engine mounts and don't know what to decide on!
    I have read all the threads and looked into all the options but what is best for a daily? I really don't want to pay £300 for a pair from Audi that will just leak and eventually fail again! Looked into 034 density line, B5 S4 Febi's and even filling mine with some polyurethane!
    Any advice from anyone who's done any of the above would be greatly appreciated.
    What are they like day to day do you feel like you sitting on top of the engine like everywhere i have spoken to suggests will be the case when putting aftermarket petrol mounts on a diesel?
    My car is not running at standard output and i have removed the EGR and with it the anti-shudder i think, which wont help i know!
  8. Chrismawa
    Chrismawa Active Member
    457
    46
    Got the solid rubber B5 ones on my TDI. They were cheap and are spot on. Firm vibration at idle over the broken standard ones, but I don't notice it anymore and may just be because the mounts aren't broke!
  9. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    No problems with mine
