B5 Audio issues & Replacement
gmx Apr 29, 2011
  1. gmx
    gmx Member
    148
    Has anyone come across cheap fix for the Concert I HUs or any seller/repairer that sells a replacement or better IC for DIY soldering?
    I'm also looking to replace front speakers with an adapter to 130mm
    Do I need to replace the tweeters or can I leave them?
    Is there an OEM "crossover" in place? If so, can I just reuse that with replacement aftermarket speakers?
  2. aragorn
    18,490
    855
    OEM crossover is an inline capacitor.
    I've left the speakers alone, but driven them from a proper 4 channel amp. Totally transforms how they sound.
    I also dumped the concert as its pretty rubbish, the aftermarket head unit also improved the sound quality no end!
  3. Bradderz_1988
    3,958
    240
    I would definitely get rid of the concert there living in the dark ages of sound quality !
  4. gmx
    gmx Member
    148
    I'd love to but I'm on a tight budget. Already stretching it by choosing to replace the front speakers instead of reglueing the dust caps on the Oem ones.
    The std sound system is fine for me. I'm not an audiophile - nor do I have the ears to be one!!
    If anything I would probably just get another used concert for $50 (yea, it will eventually fail) but the volume isn't so bad yet.
    With the OEM crossover being inline I guess it would as simple as using the existing wiring.
    With random googling I've come across some threads where plastic adapters are a nono but none of them explain why. I suppose it's due to the additional vibration they may induce as they're not a part of the abs injection molded door trim (1 piece vs 2).
    Has anyone gone from 4" to 5.25" using any of these:
    Audi speaker adaptors Fitting Adaptor - Car Audio Direct
    CT25AU03 Speaker Fitting Adapter for Audi A4 Front Door 130 mm
    Autoleads SAK-1104
  5. AndyMac
    9,832
    46
    They are all rubbish, nothing to do with vibration, just the fact they don't fit properly and leave a huge gap between the new speaker and the baffle. TBH if you are leaving everything else stock then upgrading just the speakers is a waste of money, it may even sound worse. No aftermarket speakers will sound good screwed to a flimsy door card and driven from the 2 x 12wrms the Concert "kicks" out
  6. tangerinedream
    tangerinedream Member
    249
    ditch the concert there nothing but trouble plus sound is like from a grammerphone compared lol
    heres what i did to give you an idea
    am getting the blue parts recovered soon in the same cream leather but still sounds awsome :)
  7. dann1701
    dann1701 Member
    or you could go for something like this..
  8. andybnwc
    andybnwc Member
    752
    its all down to the install and proper use of materials but still the a4s are very poor design when installing speakers
  9. gmx
    gmx Member
    148
    Looks like my post didn't actually... post here.
    Just for reference and if anyone else comes across this in the future.
    I've decided to just go with a minimum cost approach since music/audio is just not one of my interests.
    I will be repairing/reglue the standard speakers.
    Remanufacturered concert for about $20 - swap microprocessors. It's a US version so I don't think it'll work here..
    Soundproof the door card and inner skin moderately.
