B5 1.8TQ Cam Tensioner
Topplumb1 Sep 15, 2012
  1. Topplumb1
    Topplumb1 Member
    107
    Does anyone know if its possible to adjust the cam chain tensioner on the 1.8t sport quattro to stop that annoying rattleing that comes from it at idle speed, if you have the right adjustment tool 3366 tool is it ?
  2. Broken Byzan
    13,237
    466
    It's not adjustable, it's operated by oil pressure. It's more likely you have low oil pressure causing the issue
  3. Topplumb1
    Topplumb1 Member
    107
    Thats quite an interesting comment - had not thought of that, so oil pump fault possibly ? or partially blocked pick up filter in the sump could possibly be the cause?
  4. NineNails
    NineNails Proud sponsor of the snack food industry
    593
    It could simply be worn and need replaced. They don't last forever. Do the chain as well
  5. Topplumb1
    Topplumb1 Member
    107
    Any idea of part no's ninetails?
  6. snapon
    snapon Member
    37
    here ya go pal
    058109088E
  7. Topplumb1
    Topplumb1 Member
    107
    Thanks buddy - appreciate that.
