B pillar trim removal
Greeny233 Jul 21, 2012
  1. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Does anyone here know how to remove the B pillar (the one between the front and rear doors) piano black trim. I want to give it the carbon effect look and it'll be a better/easier job if I can remove it.
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    28,030
    11,162
  3. Greeny233
    1,094
    385
    Thanks Sandra, but no guide on there for removing the trim. I will have to use a bit of trial and error and hope I don't do to much error :)
  4. Z82
    Z82 Member
    454
    Fancy taking some pics to do a wee guide on it cos Im sure a few others would find it usefull (mainly me lol)
  5. L7AUDI
    L7AUDI Member
    Yeah I was just about to yank mine off and do the same!
  6. Greeny233
    1,094
    385
    Yep, I'll give it ago and take some pics. Hoping there is one in the local scrap yard that I can do a trial removal on before breaking mine :)
  7. Greeny233
    1,094
    385
    Right, no need for pictures really, removing the B pillar trims is simples.
    Open front and rear door and at the base of the trim is a plastic cover this just lifts off (lift with a screwdriver from the bottom). Under this plastic cover is two torx bolts, undo the two torx bolts and slide the trim down off a plastic clip at the top and that's it.
  8. Z82
    Z82 Member
    454
    Sounds easy :)
  9. Greeny233
    1,094
    385
    It is easy, literally child's play. Took me about 2 minutes to remove each one.
  10. tazzy baby
    tazzy baby Welsh & Proud
    569
    When you say (lift with a screwdriver from the bottom) do you lift it up to the roof or towards yourself cheers
  11. Greeny233
    1,094
    385
    Towards yourself, if you have nails you can most probably do away with the screw drive, there is just one little pin holding the plastic cover on
  12. andy.l
    andy.l Member
    224
    20
    Bump.
    Do you know how the smaller rear triangle by the rear windows is held on, did you cover this also?
    Andy
