Azureus help
Defratos Nov 21, 2006
  1. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Hey guys, not even sure if anyone can help. but I just d/l Azureus, and I need to set-up my NAT/Firewall incoming TCP port. When I do the NAT server port test it says error so I'm guessing I need to change the TCP port (currently at 60259) What I wanna ask is how can I find which TCP port to work on and connect? Thanks for any help given :beerchug:
  2. Ed
    Ed Member
    193
    Do you have a router or does your computer connect directly to the internet?
    Also what firewall do you use?
    You don't need to change the port that azureus is using, you need to allow access to your PC through the port that you have selected in azureus (60259).
  3. Defratos
    2,232
    I've got a router (belkin) and I use Nortan Internet Security. How do I find the correct port?
  4. Defratos
    2,232
    ohh and the port in Azureus (60259) came as a defualt I never entered it in
  5. Ed
    Ed Member
    193
    You will need to go into your router configuration settings (You will probably be able to get to it by going to http://192.168.0.1 or something similar). You will need to go to the port forwarding section and put 60259 in the internal and external port box, then put your computers IP address in the 'IP Address' box.
    You can find out your internal IP addres by clicking on Start -> Run -> typing cmd then clicking OK. In the black box that comes up type ipconfig then it will show you your IP (for example mine it 192.168.1.65)
    If you know the exact model number of your router then I can find a guide to port forwarding with pretty pictures etc.
    Heres what you need to do with Norton - http://firewalling.com/personalfirewalls/nortoninternetsecurity2005.htm
  6. Defratos
    2,232
    wow ok thanks mate, gimmie a few min to see what I can do,:beerchug:
  7. Defratos
    2,232
    ok I found my IP address and I got into my router settings, but I can't find the "port forwarding section" here's a screen shot think u could take a guess which option it is?
    sorry didnt realise it was soo small
  8. Defratos
    2,232
    Ok I just found a section named DMZ which:
    "DMZ The DMZ feature allows you to specify one computer on your network to be placed outside of the NAT firewall. This may be necessary if the NAT feature is causing problems with an application such as a game or video conferencing application. Use this feature on a temporary basis. The computer in the DMZ is not protected from hacker attacks. To put a computer in the DMZ, enter the last digits of its IP address in the field below and select "Enable". Click "Submit" for the change to take effect."
    Is this what I need? lol sorry for the hassel
  9. Ed
    Ed Member
    193
    Virtual Servers (although thats really obscure of belkin!)
    Put 60259 in both 'Private Port' boxes aswell if there is an option to.
  10. Ed
    Ed Member
    193
    No, DMZ isn't what you want to use, it will leave all ports open (and doesn't even work that well) and leave you vunerable. Although you do have a firewall on your PC aswell its not what you want to do.
  11. Defratos
    2,232
    ok so is this how I input it? and I write my IP and describe it as Azureus or something?
  12. Defratos
    2,232
    sweet dude, just tried it and it worked, Thanks alllllloooot :beerchug:
  13. Ed
    Ed Member
    193
    Yup, and tick the 'enable' box aswell
  14. Ed
    Ed Member
    193
    No problem, glad I could help!
