Awesome News
Discussion in 'Awesome GTI' started by awesomeade, Feb 25, 2009.
  1. awesomeade
    Offline
    awesomeade Member
    Nov 5, 2003
    46
    [Feb 25, 2009]
    Newsletter: 25 February 2009
    Awesome Custom ECU Remapping
    * A real custom ECU Upgrade *Better Fuel Ecomony *More BHP & Torque
    Using our Dynojet 4WD rolling road we are able to offer re-mapping for all vehicles from the Mk1 Golf to full blown race cars.
    Every car is put on the rolling road to be tuned and before and after power graphs are supplie
    Mk1/Mk2/Mk3 Golf £250
    Polo & Lupo 1.0/1.4 - 10% power increase £199
    1.9 + 2.0 TDI £349
    2.5 + 3.0 TDI £475
    PETROL AND DIESEL AVAILABLE
    Please call us for details about performance and pricing for your vehicle.
    Quote "ADE" when calling and you will qualify for a free Awesome T-Shirt
    http://www.awesome-gti.co.uk/section.php?xSec=1154
    Milltek 2009 Range
    The full 2009 range of Milltek is now online with a 10% discount off retail. We are also offering free fitting on all Milltek's (not including R8/RS models).
    The new 2009 list includes new cars such as the Scirroco and Leon K1.
    http://www.awesome-gti.co.uk/section.php?xSec=1096
    Bosch Aero Twin Wiper Blades
    Bosch has reinvented the windscreen wiper - Aerotwin. With the Aerotwin Bosch has redefined innovation with a design that combines optimal wiping efficiency with maximum convenience.
    Now you can retro-fit aero wipers to the following cars without the expense of new arms...
    Bosch Aerotwin Wiperblades A3 8L £21.65
    Bosch Aerotwin Wiperblades A3 8P 03-04 £22.95
    Bosch Aerotwin Wiperblades Fabia I £21.65
    Bosch Aerotwin Wiperblades Golf Mk3 £21.65
    Bosch Aerotwin Wiperblades Golf Mk4 £21.65
    Bosch Aerotwin Wiperblades Golf Mk5 £22.95
    Bosch Aerotwin Wiperblades Ibiza Mk3 £21.65
    Bosch Aerotwin Wiperblades Ibiza Mk4 £21.65
    Bosch Aerotwin Wiperblades Leon Mk1 £21.65
    Bosch Aerotwin Wiperblades Lupo GTI £24.25
    Bosch Aerotwin Wiperblades Octavia II £22.95
    Bosch Aerotwin Wiperblades Polo 9N £24.25
    http://www.awesome-gti.co.uk/section.php?xSec=1104
    NEW: Whiteline Anti Lift Kit - Golf Mk5
    From the creators of the original anti lift and caster kit for WRX’s comes the latest addition to the programme with the release of the WALK for VW Golf MK5.
    Benefits of a WALK fitted to your Mk5:
    - Revised Anti-Lift geometry for extra grip and reduced understeer.
    - Static Caster angle increased by 0.5 degree.
    - Low compliance polyurethane bush for minimum dynamic caster loss and positive steering feel.
    - Built-in axial grooves for comfort.
    - Low rotational resistance.
    - High strength anodised aluminium mounts.
    http://www.awesome-gti.co.uk/product.php?xProd=11788&xSec=1
    NEW: Open Air Vents - Pair - Golf Mk5
    Change the look of your left & right side bumper vents to match the center pieces. This OEM kit will replace the closed air vent on the left & right side of your front bumper with open air vents.
    This is a simple upgrade/install & requires simple handle tools.
    http://www.awesome-gti.co.uk/product.php?xProd=11789
    NEW: ECS Race N75 Frequency Valve 1.8T
    The N75 is the VW/Audi part identification number for the wastegate by-pass regulator valve. This valve is responsible for controlling the movement of the pneumatic actuator which drives the wastegate. The wastegate is an internal valve in the turbo-charger which controls the amount of exhaust gas that flows over the turbo impeller generating boost. Under normal operating conditions the engine's ECU sends signals to the N75 valve asking it to open or close which adds or reduces pressure on the wastegate actuator which results in more or less boost. The ECS RACE N75 valve modifies the normal operating parameters of the original N75 valve by delaying the speed at which these ECU signals are interpreted. The result is a higher initial peak boost and an elevated boost curve which tapers back to stock/chipped levels over the engines rev range. Average boost gains are 1-3psi over the rev band.
    http://www.awesome-gti.co.uk/product.php?xProd=11033
    #1
  2. Ads
    Ads
    [Dec 18, 2014]
