Avant - the strive for perfection
IanFM Dec 12, 2013
  1. IanFM
    IanFM Active Member quattro Audi A5 TDi
    452
    81
    I have posted a couple of update threads about this car (04 1.9TDi Avant) before but I'm going to stick this one up as my to do list for next year so as hopefully the encouragement (bullying/cajoling/peer pressure) from you guys will force me to do it.
    So over the next 12 months (money/time/wife) permitting
    1. Likely list
    Window Tints
    HID's Fitted (I've had 2 spare headlights and the actual HID's for about a year now so just need to fit)
    Replace Front Bumper and wing (again had them for about a year just need to fit)
    Front and rear OEM parking Sensors (guess what..... had for a year just need to fit)
    Brake upgrade to 312mm (same as above)
    Front armrest (I have one lined up)
    Twin cut out rear valance with twin outlet exhaust (coming from QuattroJames hopefully)
    Once and for all fix the pesky random brake warning light
    2. Wish List
    New headunit (currently standard concert II) don't think I'll be going RNSE but more likely double din aftermarket (aftermarket suggestions with fitted pics much appreciated) as I have the double din cage
    Meyle HD suspension arms with lowered shocks and springs and RS4 rear ARB (currently on standard SE suspension)
    3. Probably never gonna happen list
    Turbo upgrade and new remap
    So I'm viewing this as a working document that is likely to change over the course of the year but all early comments are welcome including anything you guys think I should be doing!
  2. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Double din wise I would get the Symphony 2 or with a wiring adapter kit the Symphony 2+ or the Concert 2+
  3. IanFM
    452
    81
    Thanks for the response Mike but the headunit will definitely be a sat nav/phone/mp3 combined so none oem!
  4. jbcalvin
    jbcalvin Member
    691
    21
    Does this mean I am going to be busy next year as well? :think:
  5. IanFM
    452
    81
    It just adds to the plans you have for yours!
  6. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    2,001
    220
    Send me your email addy and i'll forward you a couple of pics of my kenwood install, Garmin sat nav, bluetooth, DVD, DVB, rear screens, for me a great bit of kit.
  7. Mike.M
    2,510
    170
    RS4 rear rollbar is a must
  8. quattrojames
    14,068
    585
    Nice one Ian, headlight switch is on its way ;)
  9. IanFM
    452
    81
    OK so first question is the exhaust off a 2.5 tdi quattro a straight bolt on to a 1.9tdi fwd obviously apart from the lower valance.
  10. Mike.M
    2,510
    170
    nope
  11. IanFM
    452
    81
    Would you care to elaborate?
  12. mattyboyc
    2,001
    220
    Completely different routing of the pipe, i guess you could salvage the rear boxes, ideally you need a exhaust from a 1.8t fwd, or you can just have a rear section made and joined to your existing system, this is what i did as this mod was purely cosmetic.
  13. Mike.M
    2,510
    170
    Exhaust systems differ by taking different routes......also the exhaust from a 6 pot will not fit a 4 pot engine
  14. Mike.M
    2,510
    170
    2.5 Quattro:
    1.8T FWD
    IanFM likes this.
  15. IanFM
    452
    81
    Perfect I like pictures. Thanks for the help.
  16. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,300
    393
    +1
  17. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    i have an alpine d511r fitted in my car
    that controls cd dvd ipod + sat nav and phone all via a 7" screen a very good one shot solution
    IanFM likes this.
  18. IanFM
    452
    81
    Thanks. Do you have any pics of it fitted?
  19. IanFM
    452
    81
    So twin exhaust off a 1.8t avant is a straight swap? I hope so because I think I have found 1.
  20. Mike.M
    2,510
    170
    Yes if it is the FWD version and your car is an Avant.
  21. Mike.M
    2,510
    170
    Get the part number and it should be 8E9.... for an Avant and 8E5..... is a salloon
  22. IanFM
    452
    81
    I'm told it is from a 1.8t fwd avant and I have a 1.9tdi fwd avant!
  23. Mike.M
    2,510
    170
    That will fit fine just double check the part number
  24. IanFM
    452
    81
    Fitted new headlight switch and still have the brake warning light intermittently. Whats next brake fluid reservoir?
  25. Mike.M
    2,510
    170
    Have you replaced the brake switch that the pedal uses? Common failure and also causes the warning light to come and go until it completly fails which means no rear brake lights.
  26. Mike.M
    2,510
    170
  27. IanFM
    452
    81
    Thanks for the info mike. Anyone know how much the switch is?
  28. quattrojames
    14,068
    585
    I think they're £30 odd new?
    I have one here if you want it.
  29. IanFM
    452
    81
    Ok so quick update.
    Rear lower valance with twin cutouts has arrived from quattrojames.
    1.8t exhaust bought on ebay and enroute.
    Interior led bulbs bought from tu8ps will hopefully get installed shortly
    New headlight switch again from quattrojames arrived this morning and fitted but hasn't solved the problem of the brake warning so....
    Brake pedal switch enroute from quattrojames.
    So onward the strive for perfection goes.
  30. Ralphthemouth
    Ralphthemouth Active Member
    155
    37
    Whats the best price you've found for the meyle hd kit?
  31. IanFM
    452
    81
    Not looked into it too much yeah but think its the thick end of £400. Plenty of other things to do first for me!
  32. IanFM
    452
    81
    Ok so its a thanks to mike and James. Fitted the new break switch today and warning light issue solved. So we aren't even into 2014 yet and I can score something off my list already.
    quattrojames likes this.
  33. Mike.M
    2,510
    170
    Good to hear
  34. IanFM
    452
    81
    Grrr one problem fixed new one develops. Front demister flap stuck closed. Glove box out tomorrow I guess!
  35. mattyboyc
    2,001
    220
    Don't forget the extra exhaust bracket and heat shield, i think the part numbers are in the part number sticky.
  36. IanFM
    452
    81
    Thanks for the heads up mattyboyc. Its due to arrive tomorrow and is coming with the brackets. Will need to see about the heatshield though.
  37. quattrojames
    14,068
    585
    I've sold my one of those already lol
  38. IanFM
    452
    81
    I think I know a man that has a spare anyway. Although you might be able to help with the heat shield for the exhaust?
  39. quattrojames
    14,068
    585
    I've already had someone ask about that, if it falls through I'll let you know.
  40. IanFM
    452
    81
    I've had a delivery and can't work out what its is! can anyone guess what it is?
