Avant Speaker issue
n2w Dec 19, 2012
  1. n2w
    n2w New Member
    Hi All
    I have a 1999 B5 Avant the passenger side rear speaker has no sound from it, How do i know if my car should be fitted with an AMP/Sub or if feed directly from the Head unit, also how do i removed the rear door card to get at the speaker
    thanks for you help
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,163
    1,123
    The rears are powered by the amp at the back.
    You need to remove the screw holding the rear handle inside cover, which will show you two other screws, remove them.
    if you have rear wipers remove the handles.
    Remove the 2 little screws at either end of the door card at the top.
    the hole unit should lift up and away.
  3. n2w
    n2w New Member
    Where is the AMP located in the boot
  4. ScottD3
    15,163
    1,123
    Left hand access panel.
    There is a big black box, its at the top of that.
    You need to strip down the back to get to it.
