Avant rear wiper removal
A4 TC May 20, 2010
  1. A4 TC
    A4 TC 1.8T quattro sline
    211
    10
    Hi guys how do you remove the wiper arm ? Had a sprocket on it and I think I've done some damage oops cheers .
  2. chrisash32
    chrisash32 Member
    573
    i just did mine yesterday, removed the motor and everything... looks good with no wiper haha.
    Pulled the plastic cap off the end and then unscrewed the nut.
    Mine was jammed on tight, had to be very careful and tap the metal washer fluid pipe in the middle of the nut with a hammer until the arm came off... Be very careful if you try this yourself though..
  3. A4 TC
    211
    10
    Thanks, Tried to unscrew the nut but it was stuck solid I think I dislodged somthing from the back too !
  4. chrisash32
    chrisash32 Member
    573
    should have soaked it for a few hours in WD40 or similar...
  5. A4 TC
    211
    10
    **** soaked it for all of two minutes . no botha its going for a service in a couple of weeks , the lads can fix it then? and flipping £37 for a new wiper arm .
  6. chrisash32
    chrisash32 Member
    573
    i would just do away with it all together! looks so much better without it...
    I just have my rear window covered in rain-x so when its rains it just runs off.
  7. dope
    dope alcoholic pervert
    199
    That looks good chrisash. I might pull mine off (pardon the expression) and source a smaller 4 ring badge to disguise the hole. And do away with the existing badge.
  8. quattrojames
    14,060
    583
    Anyone doing this might be interested in THIS
  9. chrisash32
    chrisash32 Member
    573
    Good find! Thanks James :)
    I have spent hours looking for something like that!
  10. quattrojames
    14,060
    583
    What did you use if it wasn't one of those then?
  11. chrisash32
    chrisash32 Member
    573
    Rubber hole plug.....
  12. quattrojames
    14,060
    583
    Lol I 'd be worried about some vindictive tw@t walking past on a wet day and pushing the bung in!
