Avant - rear door speakers
JayB5UK Oct 12, 2007
  1. JayB5UK
    JayB5UK Member
    471
    ...Should it have any?
    Symphony Head Unit, nothing when faded to rear position.
    Only got car today, seems odd there are grilles but no sound.
  2. macattax
    macattax Member
    455
    Yeah you should definetley have speakers in the rear and also a subwoofer in the boot. Are they bose speakers? (should have a bose badge on the grilles if they are).
  3. a41.8Tavantman
    a41.8Tavantman New Member
    14
    ive got an 1999 a4 avant non bose and i dont have any speakers in my rear doors. Only front door and subwoofer behind panel in the boot
  4. livlee1
    livlee1 Member
    54
    Mate, ive got a 99.5 a4 avant,theres def rear door speakers which are 6.5" , im in the process of taking all the audi ***** out, done the fronts already, had to make new speaker adaptors out of mdf, by the way in my car the front speakers were 5" blaupunkts and 1" blaupunkt tweeters and not the nokia 4" ones:confused: ...
  5. macattax
    macattax Member
    455
    I wonder is it possible to fit the avant sub woofer in my saloon?
    Has anyone here done that?
  6. AndyMac
    9,832
    45
    Not worth it - it's totally feeble.
    You can get a stealth sub enclosure for the B5 and fit a decent 8" sub and a seperate amp which will transform the sound.
  7. macattax
    macattax Member
    455
    Where do you get the enclosures from Andy?
    Got any pics of your install?
  8. JayB5UK
    JayB5UK Member
    471
    Non-Bose, nothing there for sure and no sub, I don't think either. Or CD changer, the ********, but it does have the CD symphony unit.
    I know the standard stuff will be **** anyway, the wires should be there for the rears so i'll just buy some - what size are they? 5.25" ?
  9. livlee1
    livlee1 Member
    54
    seems strange you have no sub and rear speakers?!?!?!?
    just finished my mini install in my avant, put in infinity front comps 5.5" and 6.5" infinity coaxs and a pioneer deh-p65bt head unit, all speakers wired to the head unit so had to butcher the iso plug about but sounds much better,still got the standard sub in at the moment, awaiting new sub to come, will then run that and re-wire the front comps to an alpine amp, so should sound even better..
  10. JayB5UK
    JayB5UK Member
    471
    Hm, no changer either, probably got pinched to go on ebay!
    What size are the rears then and where does the sub go? - in the right cubby hole?
    It's alll empty, CD changer wire still inside foam..
  11. AndyMac
    9,832
    45
    The rears run off the same amp as the sub, so if you don't have the sub you can't just replace the rears without an additonal amp. All Audi headunits only have an internal amp for the front speakers, so you need an amp to run rears.
  12. AndyMac
    9,832
    45
    Here's my stealth sub in my B6 Avant
    Auto Acoustics do fibreglass stealth enclosures but I think they're only for the B5 saloon, not cheap either. Much better to make your own and in the Avant you should have enough space to be able to use MDF.
  13. livlee1
    livlee1 Member
    54
    rear door speakers are 6.5" and the sub/amp is behind the left hand boot panel....mine didnt have a cd changer either but the cable is in situ tho..
  14. JayB5UK
    JayB5UK Member
    471
    Can the amp / sub be seen through the door bit in the panel or not? Haven't really had a nose, just noticed it's all empty where i reckoned the cd changer should be.
  15. livlee1
    livlee1 Member
    54
    I can see part of the sub/amp on mine, my bracket for cd changer is still there tho, but thats all coming out soon...:cool:
