avant parcel shelf/cover
Leaky Lloyd Jul 30, 2010
  1. Leaky Lloyd
    Leaky Lloyd Member
    293
    ahdo people
    the rear parcel shelf cover on my avant has the tendancy to flip back at a rate of knots when i go over speed bumps and stuff,,is there out i can do to sort this????
  2. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    I'd be interested to know as mine occasdionally does it too. Generally it's fine though.
    Anyone?
  3. scott b
    scott b Active Member VCDS Map User
    1,254
    mine does it aswell, makes me jump sometimes lol
  4. defsix
    defsix Member
    180
    If you put an 1" of heat shrink tubing with glue inside ( electrical wholesalers should stock ) and heatshrink it on to the tabs of the roller and before it fully cools down and the glue sets put the roller into position and just push it a little into the slots to mold the glue/heatshrink. I haven't and a problem since
  5. Leaky Lloyd
    Leaky Lloyd Member
    293
    there you go fella's,,, someone with the answer,, nice one pal,,ill crack on with that then!!!!
  6. crazy88
    4,939
    437
    Excellent!!! Will definatley be trying this one soon. :)
  7. JimLoskot
    JimLoskot Member
    160
    just found this on elsa:
    part number 8E9 898 661 4PK should fix this problem
    cwrighty57 likes this.
  8. paul20v
    paul20v Audi fanatic
    1,113
    I dont see how this is happening if you have hooked it in properly .
  9. silversurfer
    silversurfer Member
    223
    Yep that worked for me too :)
  10. silversurfer
    silversurfer Member
    223
    I expect these were a optional extra from Audi.. lol
  11. blacktar
    blacktar New Member
    12
    Hi Lads, picked up my first 07 avant a while back, annd have had same problems with the cover i just got this part from audi ti fix hopefully, ordered this part number got just one of these in a bag do i need another of the same number or diferent number for left and right side, thanks in advance
  12. blacktar
    blacktar New Member
    12
    do you get both sides with this part number, got one today but only 1 in bag i presume i need a left and right , cheers
  13. MarKC7899
    MarKC7899 New Member
    Got a pair in the bag when i got mine. Not had a problem with the load cover since fitted. Cost around a tenner
  14. blacktar
    blacktar New Member
    12
    cheers for the quick reply Mark, back to audi tomorrow so, great to hear it works well,
    Adrian
  15. T0m
    T0m Active Member
    516
    26
    I too got these from Audi as it too did my head in with the cover constantly opening going over speed bumps one of lifes little niggles but well worth buying and installing works a treat.
  16. blacktar
    blacktar New Member
    12
    Cheers lads got the full kit from audi yesterday inc the 2 screw's needed. Great job:)
  17. T0m
    T0m Active Member
    516
    26
    Two screws? I just unscrewed the existing screws and used those.
  18. blacktar
    blacktar New Member
    12
    There was 2 in the kit. Could be same not sure just used them anyways. Was there some in your kit?
  19. T0m
    T0m Active Member
    516
    26
    Don't remember any being in mine fella, but saying that it was a while ago that I did this!
  20. SDHA4SLine
    SDHA4SLine Well-Known Member Team Silver Audi Avant Owner Group S-line owners group
    2,608
    513
    Does this part fit B7 avants?
  21. #Nick
    #Nick A4 Avant 1.9TDI PD130
    80
    1000 ASN points to JimLoskot!
    Scares the s**t out of me when this happens!!
    Lafarge likes this.
