avant coilover question
glenandem Oct 13, 2013
  1. glenandem
    glenandem Active Member
    772
    55
    got me some fk coilovers for the avant and although ive fitted them to other cars im just wondering should i put the adjuster platform at the top or bottom of the rear springs for access and what do you guys use to keep the threads from siezing?
  2. hades-
    9,481
    646
    bottom on thr FK no choice
  3. glenandem
    772
    55
    cheers pal,take it youve fitted them,canou tell me what you thought of them for budget coilovers?
  4. hades-
    9,481
    646
    yes to a few cars
    there ok to start with but you can tell there budget soon after
    can cause a few knocks and bangs if to low
    and quite a bot of bounce.
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Iv got Weitec coilovers on my Avant.
    Been on for around 10 months and have not had any issues - I fitted the adjuster to the top of the rear spring.
    Can be abit of a pain adjusting as I need to take tension of the spring before turning - usually use a long breaker bar.
  6. glenandem
    772
    55
    just off hand,why cant you fit the fk adjuster to the top like others,is it the way its designed etc?
