Avant boot release help/info please
dannyFR+tdi Jan 18, 2010
  1. dannyFR+tdi
    dannyFR+tdi Member
    212
    Hey,
    Ive been having problems with my boot from when i washed it yesterday, When you close it the dash display is still showing that it isnt closed when it is, Are there any common faults which it could be that i can check myself before going to a garage to have it looked at??
    Any help/info would be really appreciated
    Danny
  2. dannyFR+tdi
    dannyFR+tdi Member
    212
    Is there a sensor or solanoid to detect if the boot is closed or not?
  3. dannyFR+tdi
    dannyFR+tdi Member
    212
    Anyone please help me with this one?
  4. BILKO1
    BILKO1 Member
    301
    There is a micro switch built into the lock catch, if yours is an avant you have to buy the whole assembly (like i did) if it's saloon or cab you can buy the micro switch separately if i am reading etka correctly. Take it apart and check the wiring first as it does seem to get water ingress.
  5. AU01 A4
    AU01 A4 Member
    211
    I had the same problem, i used oil on the lock mechanism and have not had the problem since and that was a year ago.
  6. dannyFR+tdi
    dannyFR+tdi Member
    212
    Thanks for the reply so i need to check the micro switch in the lock assembley, i think its due to water as it only started being faukty after id washed the car, Any chance you have the part number and price of the part please incase i do need to replace it
    Danny
  7. BILKO1
    BILKO1 Member
    301
    What model have you got? Avant etc.
  8. dannyFR+tdi
    dannyFR+tdi Member
    212
    Its an 04 avant sport tdi130 mate
  9. BILKO1
    BILKO1 Member
    301
    4B9827505N is the part number its called a flap lock item 17 on ETKA, the microswitch is item 19 not available separately for the Avant :(
  10. dannyFR+tdi
    dannyFR+tdi Member
    212
    My hero shall get a price from audi or should i try anywhere else first? Yeah i was told its the full assembly that i would need
  11. BILKO1
    BILKO1 Member
    301
