Auxiliary Heater (Z35) - DTC
rick28 Mar 20, 2012
  1. rick28
    rick28 Member
    46
    Hi all
    I have done a scan for DTC's on my Audi A3 2.0 TDI 2004 and I have the following 2 DTC's. I didn't even think my car had an Aux Heater? I have looked through the manual and the fuse (F30) is the only thing that mentions the Aux Heater, and there isn't even a fuse in that spot anyway. Can anyone advise?
    Address 08: Auto HVAC Labels: 8P0-820-043.LBL
    Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
    Component: KlimavollautomatH12 0150
    1 Fault Found:
    00483 - Control Module for Auxiliary Air Heater
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 84
    Mileage: 183448 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 18:22:11
    Freeze Frame:
    ON
    Address 7D: Aux. Heat Labels: 1K0-963-235.LBL
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    Rick
  2. audigex
    audigex Active Member
    600
    46
    I saw mention of it in my manual - didn't really pay attention because it warms up reasonably quickly, I've got heated seats anyway, and it's never cold enough here to need it. Could it be right that ere are two additional heaters possible, one in every TDI (because it takes longer to warm up) and one for cars exported to cold countries?
  3. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Auxiliary Heater mentioned in your VCDS reading warms up the cold air before the coolant reaches the temperature, heating up the air coming through the air vents as soon as you start the engine.
  4. 20pricey11
    20pricey11 Member
    73
    I'm getting theses faults and I spoke to Tps and they said it's not fitted to my car
  5. fangio
    fangio Well-Known Member
    1,514
    180
    Weird! How can you get a fault in something that doesn't exist?
  6. 20pricey11
    20pricey11 Member
    73
    Not got a clue mate
  7. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    There may be some confusion over the term. In Scandinavian countries you can spec an auxiliary heater which is designed to warm the car up in the morning before use. You can set a time for it to come on. That option isn't available in the UK though (I tried to spec it myself).
    The heater element mentioned by SAiLO probably has a different name but it's certainly fitted to TDIs.
