AUX SOCKET !
shilts Mar 20, 2010
  1. shilts
    shilts Member
    222
    Hi , excuse my ignorence but what can the Aux socket in the centre console be used for , thanks ?:think:
  2. waqi
    waqi Member
    150
    plug your ipod or anything with a headphone lead in :icon_thumright:
  3. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    installed this myself yesterday, great cheap little mod, ideal for iphone/ipod
  4. shilts
    shilts Member
    222
    Thanks waqi , does this just give you charging capability or can you play through this ?
  5. 1wheelonly
    2,385
    111
    no charging, just plays audio
  6. shilts
    shilts Member
    222
    Thanks , why would you then want ipod connection in the glove box - i thought all had aux socket !
  7. Tenexx
    Tenexx New Member
    10
    Hi there,
    The ipod connection in the glove box will also charge your ipod & it also becomes a functioning part of the radio so you can forward, skip & repeat tracks etc with the radio controls rather than fiddling with you ipod whilst driving. Im not totally sure but i think the AUX socket will just play through the radio speakers. Hope this helps.:o.k:
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    also for audio buffs i belive theres less quality sound as its only 2ch mono over aux, though to most its unnoticable, its all down to preference really
  9. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    "2-channel mono"
    Er... that's as reasonable a definition of Stereo as I can come up with!
    "less sound quality" as a result of being "only 2ch mono" is unadulterated balderdash.
    I have the iPod -which charges, controls and sends signal and control data to and from the iPod. -I also have the aux input (currently temporarily mounted on an in-line 3.5mm socket, since I'm waiting for the real OEM part to be delivered) which allows me to squirt in an additional signal from an HD radio tuner. You could also use it for game audio from a playstation/sound from a portable DVD player/zune or other aftermarket mp3 player... anything that is external to the available audio sources to the car, which you'd like to hear through the speakers.
    Keith
  10. shilts
    shilts Member
    222
    Thanks guy's !
  11. samil87
    samil87 Member
    31
    How did you do this??
  12. VWAddict
    656
    9
    Depends on the head unit.
    For an RNS-E, you buy the (62-pin or 32-pin, I can't remember) connector and pins for the back of the head unit, and solder extension wires up to your socket.
    Then you break out the VAG-COM and reprogram the RNS-E to add 'external aux input' to its list of inputs.
    As for the Concert and Symphony variants, I've never done it, but I assume it's probably something similar.
    Keith
  13. 1wheelonly
    2,385
    111
  14. PH1L
    PH1L Gievf Buckets
    3,851
    40
    haha i suspected so i'm quite happy the way ive got my zune hd set now through a soundgate core for the video output <3 my zune
