AUX Input - Symphony II+/Concert II+
yorkster001 Feb 7, 2011
  1. yorkster001
    yorkster001 Member
    92
    I completed the aux input install detailed in DIY: Aux Input for Symphony II+on my Concert II+, but with a slight modification. Instead of mounting the socket in the dash I chose to route it to the arm rest. My reasoning was that I don't like a cluttered dash (cup holders, phone holders etc...) so this way my media player can be hidden away. The added advantage is the DJ (oldest daughter) can be seated in the back and still control the decks. Just fortunate she has good taste in tunes (Rock!). Pics to follow.
  2. yorkster001
    yorkster001 Member
    92
  3. unikarl
    unikarl Member
    367
    Good work though I think yours is the Symphony 3 not 2.
    I want to do this to mine but mine is the 2 so I dont think it will work.
  4. yorkster001
    yorkster001 Member
    92
    Mine is a Concert II+, I think the Symphony has the CD Changer which I don't.
  5. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Symphony 3 is what's fitted to the B8 A4.
    Later B7 A4's have the Symphony/Concert II+, with early B7's and all B6's having the Symphony/Concert II.
  6. unikarl
    unikarl Member
    367
    So if I have a concert 2 can the aux input be added?
  7. yorkster001
    yorkster001 Member
    92
  8. Samir Motala
    Samir Motala New Member
    Im trying to fit the symphony III part no. 8E0 035 195 AD in to a b7 which has a Concert whjich plays mp3. Will it be avsimple straight swap?
    Also i have nokia bluetooth kit connected - wil the symphony work with it?
  9. benr
    benr Member
    819
    I have a symphony II+ (the one in this post) which has mp3 support and works fine with my nokia bluetooth carkit
  10. Ricey
    Ricey New Member
    I have a concert II stereo which I was planning on adding a jack in the glove box, does anyone know if I can solder the aux cable into the back of the stereo as I would prefer not to have to pay 30 euro for a aux cable with jack
  11. PetrolDave
    1,559
    85
    That's a Symphony II+ not a Symphony III - as proved by the 8E0 prefix.
  12. PetrolDave
    1,559
    85
    Only the Concert II+, Symphony II+ and RNS-E support the separate Aux In - with all other Audi radios you would need the CD changer adapter to get an Aux In.
  13. Ricey
    Ricey New Member
    Thanks for the update. My question is what connections at the back of the stereo are the CD inputs left and right
    This guy seems to show how to do it, but not sure why he uses a relay
    An Auxiliary Audio Input to the Audi OEM Head Unit and CD Changer
  14. PetrolDave
    1,559
    85
    What's he's doing is putting the relay in the analog audio connection between the CD changer and the head unit - when you throw the additional switch the relay operates so when you select CD on the head unit what it actually receives is the Aux In audio.
    So you also have to fit this additional switch to choose between CD changer and Aux In somewhere on the dash - and you can't use a standard Audi dash switch as they are all momentary and not latching.
  15. Ricey
    Ricey New Member
    But the Concert II is a CD Player so I wouldnt have to switch between a multi CD player and the AUX
    Is there a multi CD input and if so can you connect direct to it without the relay using just a jack to jack cable
    with one end cut and the following connector into the back of the stereo
  16. PetrolDave
    1,559
    85
    Yes you would, switching between the internal CD player and the external one is built-in to the firmware (the internal CD is CD1 - or 1 to 6 if it's a changer like on the Symphony - and the external CD changer is CD 7 to 12 (or CD 2 to 7)).
    Nope, the head unit needs to see the correct information on the CD data line to know that there is a CD changer (or emulator) plugged in - without that it won't enable the CD audio input.
