Aux in question
A3simon Aug 27, 2009
  1. A3simon
    A3simon Active Member
    982
    40
    Right my mum just got a new TT with a Symphony Cd headunit with the Aux in function and socket which worked fine i then fitted an RNSE and it all works perfect except the Aux in is there a code i need to change to get it to work with the RNSE
  2. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    yes, i think you have to code it and tell it it has a cd changer, im sure the rns-e input for the aux in is the cd changer.
    im sure someone will comfirm simon.
  3. NHN
    29,525
    1,766
  4. A3simon
    982
    40
    Ok well on the RNSE itself in the cd menu there are 3 options cd changer mp3 and aux in surely the aux in is seperate from the changer as the changer is an option that can be used at the same time
  5. NHN
    29,525
    1,766
    Yes the cd changer connects via the quadlock & the aux in utilises the 32pin connector above the antenna connectors on the rns-e, so it is seperate.
  6. A3simon
    982
    40
    so thats where the problem comes from then as it doesnt have the 32 pin connector
  7. NHN
    29,525
    1,766
    Just get a 32 pin connector for the rns & move the pins over, think the pins are same size, fairly easy job tbh Si.
  8. A3simon
    982
    40
    cheers that will be a task for when im next home then
