Automatic Wipers
BigD289 Sep 6, 2013
  1. BigD289
    BigD289 Member
    104
    13
    Does anybody know how to turn on the automatic wipers?
    They seemed to work before but are now not coming on. I've checked and Rain Sensors are enabled in the MMI.
    Does anyone know if you have to do something special to get them working, is it like the lights where you have to set it to auto?
  2. NHN
    29,351
    1,720
    Usually stalk is pushed up to the 1st position if rain sensor is fitted.
  3. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,563
    1,170
    Yeh, just adjust the stalk. You have to be moving as well. I had to 'kick them off' this morning and set them going by pulling the stalk towards you briefly (not long enough for the washers to come on though), but it takes over from then and worked fine. I put the sensitivity up high though!
  4. BigD289
    BigD289 Member
    104
    13
    Cheers, I'll give that a go!
    I did spend minutes with water on the windscreen wondering why they weren't coming on. In the end I manually turned them on and then was wondering why they didn't switch off when it stopped raining. I guess you get used to them 'just working'!
  5. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,688
    526
    I'm sure I remember my dealer telling me the lights had to be set to Auto to also enable the auto-wipers.... although I might be imagining that!
  6. Daveotto
    Daveotto Well-Known Member Team Floret Silver Gold Supporter Audi S3 S3 Saloon
    2,876
    4,170
    The rain sensor calibrates itself when you turn the ignition on so if there is rain on the windsreeen it sees this as being clear/rain free and the auto function will not work as it does not "see" any new rain. But as long as you do as cermerson describes tokick start them they should work perfectly.
    Out of habit, i swipe the wipers whenever there is the sightest bit of water on the screen when i first get in.
  7. coolguy
    coolguy Member
    144
    19
    That's just happened to me on my way home. Got in the car, water on the windscreen but the wipers didn't move so gave it a wipe. Then after at it worked itself.
  8. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    952
    394
    Still haven't got the hang of mine.
    They seem to be governed more by vehicle speed than amount of rain actually on the screen.
    Yes Comfort pack and yes stalk in right position.
  9. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    6,040
    1,778
    Strange system the Audi seems to have. I have a Ford and I always leave mine off until it starts raining then turn it onto automatic and they work fine, The only link to the headlights is when they're also set to auto and it starts raining and the auto wipers are used during the day they will come on. The calibration should happen every so often as there is no point it happening at first ignition on...
  10. Vertigo1
    Vertigo1 Well-Known Member
    3,472
    627
    They will work when stationary, they just slow down a bit.
    Also, bear in mind that if you start the ignition with the wipers switched on (any position other than off), then the wipers won't operate at all until you actually start moving. This is a safety feature for cold winter days when the screen and wipers could well be iced up in the morning.
