Automatic locking when car is moving
banoffee Sep 11, 2009
  1. banoffee
    banoffee Member
    124
    Is this a VAGCOM setting?
  2. Nilz
    11,329
    876
    Yes it is.
  3. banoffee
    banoffee Member
    124
    thought so, cheers
  4. Westy
    Westy Well-Known Member
    17,443
    1,103
    On the same subject. I have this enabled on my central locking pump, which was replaced last week and I have noticed the following. My old pump would auto lock at around 12mph and my new pump locks doors at 20mph!!!!!
  5. Broken Byzan
    13,237
    465
    No pleasing some people..... LMAO
    At least you got it sorted now, i don't recall a specific setting for the actual speed, just the coding to enable/disable
  6. Westy
    17,443
    1,103
    My problems is still not sorted mate even after the new pump, it appears to be something else at fault. But I did I need to be going quicker to lock my doors :laugh:
  7. Nilz
    11,329
    876
    Im sure its defaulted to 10mph, but cannot confirm.
    Westle, this just means quicker take off now :)
  8. Westy
    17,443
    1,103
    haha yeah I now need to launch to 20mph from stand still so that my doors lock and I dont get hi-jacked.
  9. Broken Byzan
    13,237
    465
    Launch control FTW,lol
    Now you have a reason to turn the ESP off. he he he
  10. Westy
    17,443
    1,103
    ESP is always off in my car anyway. I was going to have a hunt around in VCDS to see if I could revert the ESP button so that it was off as default and you have to push the button to turn it on! :racer:
  11. kitpayne
    kitpayne Member
    129
    you wouldn't need it to self lock if you pull away like that all the time, hijakers wouldn't have a chance of getting in away. lol :lmfao:
  12. Westy
    17,443
    1,103
    There's some pretty fast jackers where I live mate :)
  13. ikbenben
    ikbenben Belgium S3 driver
    105
    I've searched today in vagcom to get it working but i couldn't find it how to :ermm: I couldn't get into group 46 (cent. conv)
    I thought that every S3 had the possibility to change that?
  14. sportquattro
    sportquattro Active Member
    835
    51
    Probably a daft question, but whats the reasoning behind doors locking above 10-20mph? Presumably when this feature is enabled they also unlock below this speed so would be no use against car-jackers - or I am i missing something obvious
  15. ikbenben
    105
    They don't unlock below that speed. They unlock when you pull out the key or when you have an accident.
  16. S3KO4
    S3KO4 Member
    850
    Could also be some sort of a kid safety thing, so they wont open the door by mistake, above certain speed as it will leave it off in case you have short trip or parking etc. not sure just thinkinh behind the logic.
  17. sportquattro
    835
    51
    Ahhhh all is clear, many thanks
  18. ikbenben
    105
    Np ;)
    To open the door from the inside you have to pull the handle twice also.
  19. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    ive got to take the facia off my stereo before the doors unlock :think:
  20. Westy
    17,443
    1,103
    Mate you need to use this tool:
    http://www.kevin-st.co.uk/tt/BaseCode/Basecode.zip
    You put in your coding into the box and it will tell you what features you have enabled. You then tick the boxes forthe features you want and it will give you a new code to enter into 35 central locks.
  21. ikbenben
    105
    Well, it will get sorted out next week.
    I know somebody with lots of knowledge of vagcom. He will do it for me.
    About that little tool...where do you find your basecode :unsure:
  22. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    I second that, where is that data? Most useful....
  23. Westy
    17,443
    1,103
    Sorry guys I should have explianed better.
    The base code is under the Central Locks module number 35 in the "coding" field. You can also get it from one of your VCDS logs like the following:
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 16234
    Shop #: WSC 01236
    No fault code found.
  24. ikbenben
    105
    Thx Westle, I used the tool today after i've searched the base code and it works :beerchug:
  25. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Mine's never had this feature since I've owned it, will I be able to enable it? Or will the option not be there?
  26. ikbenben
    105
    It probably will.
    If you have vag-com or somebody you know try it with the tips Westle gave ;)
