Automatic Headlight warning light
themikeyboosh Feb 22, 2011
  1. themikeyboosh
    themikeyboosh Member
    68
    I've tried a search but can't see any info.
    Recently, I've had the automatic headlight warning light popup on the dashboard, but while it's on, the headlight still continue to turn on and off automatically (if I go under a fly over for instance, they come on)
    It's only came on twice, once about a week ago when I started the engine, and this morning after about 5 mins of driving.
    Is there anything I can do to troubleshoot this? I am led to believe that the a new sensor would require a new windscreen? I could be wrong there?
  2. kite
    kite Member VCDS Map User
    677
    it prolly the auto leveller playing up.
    Scan for faults with VCDS.
    There is a sansor on the front and rear suspension.
  3. themikeyboosh
    68
    Do they auto level as well? I've got a dial to adjust the level that near the headlight switch. I wasn't aware they levelled automatically as well.
  4. kite
    677
    My mistake, I assumed you had xenons as you have autolights.
    A fault code scan would be the first step to finding the problem.
  5. audicruiser
    audicruiser Audi Heaven
    1,865
    No they don't as you don't have Xenons... Do your Auto Wipers still work??
  6. themikeyboosh
    68
    Don't have auto wipers, just the lights.
  7. Lewbo
    Lewbo Well-Known Member
    1,274
    106
    if you have auto lights then you have auto wipers as they use the same sensor mate
  8. themikeyboosh
    68
    Really? I'll be physically taken aback if this is true. Mines quite old, it's on a 53 plate. Maybe they do in the new ones?
  9. NHN
    29,596
    1,782
    As advised, scan the car to determine the fault 1st, could remove the headlight switch to see if connector has come unplugged aswell, but scan will definitely point you in right direction.
  10. themikeyboosh
    68
    They still do work though, they switch on when going under a fly over then turn back off again when I'm out.
    Thanks for the advice, I'll get it scanned.
  11. NHN
    29,596
    1,782
    You're confusing 2 different systems, auto lights are nothing to do with levelling systems, 1 will work without the other.
  12. themikeyboosh
    68
    thanks to everyone who replied, it's sorted now;
    I had it scanned as suggested but it didn't return any errors for the auto lights feature, but it did tell me both my tail lights were out. Had a quick look, both had blown, 2 replacements and £4 later and I'm very happy! Not sure why these would trigger the warning light, maybe cos I don't have DIS and it tries it's best to inform you anyway it can!
    Thanks again.
  13. audicruiser
    1,865
    I would now be worried as to why they BOTH blew... I mean one yeah ok. But both at the same time??!!
  14. themikeyboosh
    68
    Coincidense is always a possibility no matter how unlikely you may deem it. Murphy had the right idea. Besides, they might not have blown at exactly the same time.
