AUTOMATIC GEARBOX SPECIALIST IN THE NORTH EAST
white.akita Sep 5, 2012
  1. white.akita
    white.akita Active Member
    322
    30
    hi, im looking for a automatic gearbox specialist that can competently change the gearbox oil in my 2006 2.0tdi automatic gearbox.
    i have print outs from audi stating its had a new gearbox ecu and oil change at 80,000 miles but the car is now at 150,000 miles and id like it replacing for peice of mind ?
    anyone recommend one ?
    also as i say the ecu was changed at 80,000 miles so whats the chance of it going again at 160,000 miles or could of it been replaced with a uprated version that are now available ?
  2. BigWillyStyle
    BigWillyStyle Member
    566
    58
    I'd be interested in this also.
    What are the symptoms of a ecu that needs replacing as my car is having some mood problems?
  3. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    Audi A4 auto box is a sealed unit and does not need the fluid changing. I've spoken to Audi and a few independants about this thinking an oil change can only do it good, however due to the ECU being mounted within the gear box changing the fluid usually does more harm than good. Or so they said.
    If it ain't broke...
  4. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,399
    2,943
    Your information is correct, but only for the traditional ZF auto box fitted to A4 Quattros. However, the front-wheel drive models are fitted with the Multitronic CVT auto box, and it is imperative they have the oil changed every 40,000 miles without fail.
  5. Joe_Murphy21187
    1,064
    71
    Cheers for confirming Jeff. Guess I never though about the multitronic boxes... Is the ECU still mounted within the gearbox itself? One of the specialists I spoke to seemed to imply that the ECU (in the tiptronic box) is actually submersed in the transmission fluid... I can only assume if that is the case it's withing a sealed casing of some sort??
    Wondering if changing the oil in the CVT box can potentially cause problems or if it's a fairly standard proceedure...
  6. smokeymike
    smokeymike Active Member Team Mythos SQ5 owners group
    167
    34
    Give Autotechnica in Hull a call. They are both ex Audi Master Technicians and do a really good job. They won't do any work that isn't required. 01482 353369.
    Hope this helps.
  7. jdp1962
    8,399
    2,943
    NOT changing the CVT oil is problematic, as it will just ruin the box. Changing it is a routine (albeit rather slow) process for all Audi dealers and most reputable indies. Typical cost between £150 and £200.
    Not sure about the ECU location, but from memory, it is external rather than internal.
  8. white.akita
    322
    30
    hull is a bit far from me, anybody know anywhere closer that can do it ?
  9. Paul B7
    Paul B7 Active Member
    622
    34
    My unreserved vote for Autogearbox builder par none would go to "Easy Gears" in Thornaby , Stockton on Tees.
    I have used and recommended them for the last fifteen years and all who have used them speak very very highly of them.
    The owner and Autogearbox Guru is called Terry.
    Not much known but most of the local main dealers use this mans services.
  10. white.akita
    322
    30
    thanks very much i will give them a call, i have also found a company 5 mile from me called s cars in spennymoor, they quoted me £130 for a cvt oil change.
