Automatic gear knob remove
ScottD3 Apr 11, 2011
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    How do you remove the gear knob from an automatic?
    I need to remove mine.
  2. 205man
    205man Active Member
    1,072
    14
    put shift into 3rd, slide the sleeve under the handle that covers the stick itself down, then pull the selector button out, and lift up the handle of the stick.
    if that makes sense lol
  3. ScottD3
    15,164
    1,123
    Thanks, I'll give it ago tomorrow when i'm parked.
  4. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    let us know how you get on i may need to do this soon
  5. ScottD3
    15,164
    1,123
    I'll film it. :)
  6. ScottD3
    15,164
    1,123
    I tried that and it did not work.
    How far down should the sleeve go and how hard should it be to move?
  7. 205man
    1,072
    14
    i know it worked on mine as i did it to remove the trim at the bottom to cover in carbon wrap as it was worn, ive got the audi mechanic manual and it show how to remove there, i can email it to you if you pm me your address
    the sleeve just goes down as far as you can push it. but the handle will take some effort to pull of as they are on tight
    alan
  8. ScottD3
    15,164
    1,123
    Done.
  9. ScottD3
    15,164
    1,123
    I did it this morning and almost smashed my self in the face with it (I did this on my BMW and cut my eye!!).
    I dont think the gear really matters but I would recommend 3rd or D.
    1, Put selector in to 3rd or D
    2, Pull out the button and use a cable tie or some other form of wedge to keep it out at the bottom of the button
    3, push the shaft sleeve down by about 5mm. Its a bit stiff and will need some pushing. When you done it right you will hear it click. I used the flat surfice of my pen knife blade
    4, pull up on the knob as had as you as can. But make sure you stuck the selector open. I dont know what damage this will do to the small plastic section that this knob clips in to.
    O yeah, and keep your head out of the way as it will come off with some force.
    Thanks for info 205man.
  10. rasA4
    3,287
    119
    i didnt film that as well did you,lol
  11. ScottD3
    15,164
    1,123
    LOL.
    No, I should have done.
    But thinking about what happened last time I hit my self in the eye I learnt to keep my head away.
  12. rasA4
    3,287
    119
    ouch .. you ok now ?
    you managed fit it back ok?
  13. ScottD3
    15,164
    1,123
    Yeah i'm all good man, That was done years ago.
    That was a BMW gear shifter. I got in trouble in work, they thought I did it on perpus so i could go to a car show.
    The Audi knob is back on and working.
    Just make sue the button is out all the way and you put it on straight. If the knob is on an angel it will not fit correctly. No need to force it on either. A gentle tap at the end is all thats needed.
    I'm having issues getting the chrome sleeve back up to lock it in to place. I can't get enough grip on it.
    Do you know if the Auto knobs from other Audis/VAG will fit a B5?
