Autoglym Surface Detailing Clay Kit
Iain 750 Jan 2, 2011
  1. Iain 750
    Iain 750 Member
    75
    Have just bought myself one today and wondered if anyone has any tips for a novice detailer like me as ive never clayed before!!
  2. Padtwo
    Padtwo Member
    62
    First off you don't need to scrub the body work with it, just a bit of light pressure. Lightly mist the panel then slide the clay bar across repeatedly until the surface feels smooth. Car should obviously be clean before using the clay and you will have to give the car another wash afterwards as it will leave deposits behind but the paint will/should feel silky smooth afterwards.
    IMPORTANT: If you drop it, bin it!!!!!!!! It is therefore useful to split the clay bar into several smaller pieces incase this happens. The clay bar should also feel soft'ish, leave half in the garage and half in the house for an hour or so and you'll see the difference temperature makes to it!! I tend to warm it for a while first, but this can make it quite sticky so I put it on a bit of paper or something disposable (I left it on a dashbord in the sun while I cleaned the rest of the car once...) Also if you have split the bar into several bits then you can be warming one bit while you are using the other, then change etc. Finally for storage keep it in an airtight container as they dry out, I use a sandwich bag.
  3. barnzy
    barnzy Member
    97
    Great Advice from Padtwo!
    Remember to always keep the bodywork moist, Give it a good wax after too, ive never used auto glym always been a fan of meguirs.
    There is some serious difference once you have clayed it... very impressed with the results after i did mine.
  4. tdia4
    tdia4 TDIPOWARRR
    613
    I find putting the clay in a cup of warm water helps to keep it soft.
