auto window close
sachen Apr 3, 2011
  1. sachen
    sachen Member
    246
    Hi Guys,
    I have a 2006 A3 Sportback. When i first got the car, if you lock the doors and the windows were open they would close if you kept the lock button pressed on the fob. For some reason this has stopped working. Ive had a look through VCDS and they are still enabled.
    Anyone know what the problem could be?
    Thanks!
  2. Ads
    Ads License to drive
    8,230
    612
    Maybe the battery in your key needs changing.
    If it's getting weak then the continuous signal the car needs to do the auto close may be fragmented and therefore not work properly.
    Autoclose on my last A3 used to randomly work/not work until I got a new battery.
  3. mike foster
    3,967
    After battery disconnect you have to reset the windows before this feature will work.
    On each window in turn - wind down and hold at the bottom for a couple of seconds and then wind up and hold for a couple of seconds.
    After this has been done it resets the start and finish positions and re-enables auto close. (or it did on mine !!)
    aeroeng likes this.
  4. sachen
    sachen Member
    246
    Cool. Cheers for that! Will give it a try when i get back to my car post work
  5. welshwoody
    welshwoody Member VCDS Map User
    438
    10
    With mine you have to press the button once to lock it, then press it a second time and hold it until the windows are shut. The same goes for opening them, press it once to unlock, then press it again and hold until the windows are open as much as you want them to be.
  6. mike foster
    3,967
    That's dead right but if you've disconnected the battery they need to be reset by the method I explained before they will work again.
  7. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    Im pretty sure we enabled the one-touch windows after the Cruise install Sachen, which should have then activate the comfort closing.
    I was a bit confused by it as well when it wouldnt work by the buttons..
  8. mike foster
    3,967
    All part of the same problem Jonny !
    Just do the reset mentioned and all will work ok !
  9. sachen
    sachen Member
    246
    Yep, it was definately enabled on VCDS... its all coming down to window down and up the windows and see if that works! Im still at work so wont be able to check at the moment!
    ps: Thanks Jonny for the cruise install! :o.k:
  10. Ads
    8,230
    612
    :lmfao: @ this thread!!!
    One question................ WAS THE CAR BATTERY BEEN DISCONNECTED AT SOME POINT BETWEEN THE WINDOW AUTO CLOSE WORKING AND NOT WORKING???
  11. mike foster
    3,967
    C'mon mate - no need to shout ! Afaik there should be no other reason for them to stop working, apart of course from a flat key fob battery like you pointed out or disabling with VCDS !
  12. sachen
    sachen Member
    246
    originally...no
  13. jb0o
    2,664
    118
    I think people are getting confused with the actual problem here.
    As Mike says the comfort closing via remote is activated by activating the one-touch windows, and as Mike said, this is activated by the sequence of operations on the electric windows switch.
    The problem though is that Sachens one touch windows have been activated and are working however the comfort function closing windows via remote isnt working. All settings have been checked in VCDS.
  14. Ads
    8,230
    612
    Sorry for shouting. Although it was more of a comedy shout than an angry one!
    Originally no? So you mean the auto windows stopped working BEFORE the battery was disconnected?
    Also, do your one-touch up and down windows work when using the electric windows switch?
    If they do still work then your problem isn't anything to do with requiring a window reset, IMO.
  15. Ads
    8,230
    612
    Haha, just seen your last post jb!
  16. sachen
    sachen Member
    246
    Yep, one touch up and down still work. The only part that doesnt work is when you lock the car and the windows close.
  17. sub39h
    sub39h Active Member
    2,502
    if your car is due a service or some work at Audi at some point in the near future get them to sort it out. they do this sort of thing for free for me
  18. Ads
    8,230
    612
    Are you still able to lock the car via the fob from a fair distance? i.e. 15-20 meters away.
    If not, then as I said, try a new battery in your key.
  19. jb0o
    2,664
    118
    Yeah I think the same, I think it could be down to the fob. Did you try your spare key Sachen?
  20. jb0o
    2,664
    118
    Any progress on this sachen? Installed into a '57 2.0TDI 170 yesterday with the same issue.. Very strange!
  21. sachen
    sachen Member
    246
    I do have progress. they just randomly started working again without me having to do anything....
    dont ask as dont know why!
  22. jb0o
    2,664
    118
    Haha, good job mate! Hope all is well!
  23. a9503128
    a9503128 Guest
    Cool, love it when I find a new feature on a car. Thanks
  24. sachen
    sachen Member
    246
    Was pretty strange the auto close stopping working and then starting again.
    heres to hoping something else starts working that adds an extra 50hp to the car.:racer:
  25. quattro81
    quattro81 All the gear.. No idea
    970
    90
    My drivers window had stopped winding all the way up and down with one touch of the switch.. I tried this and it now works perfect again! Nice one mate!:thumbsup:
  26. NHN
    29,577
    1,779
    There are 4 systems in play here:
    1st automatic run should be active in the door modules which tbh is default from audi anyway which allows one touch in the 1st place
    2nd coding window closure via remote, which is done by when locking continue to hold lock & it will make windows go up, but will stop when you release button
    3rd coding comfort closing via remote that actually will when you lock & hold button continuously, make the windows go up & when you release the button will still continue to close
    4th is making sure the one touch is setup via the reset method with window switches.
    Hope that helps :)
  27. quattro81
    970
    90
    Hi mate, thanks for the info.. So ATM I have 1st, 2nd working ok (and cos I have new dis I can select comfort window closing on the remote on there?) but number 3 means windows carry on closing after I release fob button? I take it that this function has to be enabled with vcds? If so its probably bout time I bought a cable from you bud!?
  28. Vazza
    Vazza Member
    79
    Would like to know this too as my S3 does 1 & 2 but not 3?
  29. NHN
    29,577
    1,779
    I've always enabled this feature via vcds yes.
  30. Rhyso
    Rhyso Well-Known Member
    1,536
    320
    So if you coded in the 3rd option can you stop the windows going up by pressing the lock button again?
  31. NHN
    29,577
    1,779
    TBH never used that feature, but yes it does that
  32. DSB
    DSB Member
    60
    So you can only enable option 3 with VCDS - i.e. there is no way of doing somekind of electronic vodoo - hold the key fob button down for 10 seconds, touch your toes, kiss your Mrs - sequence to enabling it ?
  33. NHN
    29,577
    1,779
    If you wanna try some of those & stick it on youtube, sure you'd gain a good following :p
    But, I've always done via vcds & I dont know anyother way to enable this.
  34. DSB
    DSB Member
    60
    cool, just re read post and you kind of made it clear before really :salute:
  35. Rhyso
    1,536
    320
    Excellent - cheers for that. Will save the battery draining on the key fob :)
