Auto window close / open...?
burnsy79 Mar 26, 2012
  1. burnsy79
    burnsy79 SQ5 Driver
    Guys / Gals,
    I've been a member for a while but never posted, so apologies in advance if I'm running over old ground.
    I have a 2010 A3 TDi Sportback Sport 170 and the comfort window open and close was never default on my car. I've scanned a few posts and all seem to say you require the VCDS to switch this on. I was under the impression this was a default setting, how do you reset without the VCDS?
    I had a 320 BMW before and you could reset by a combination of buttons pressed on the fob when it was in the ignition... Any help would be great?
    Burnsy
  2. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    883
    Are you talking about the one touch facility on the windows....If so then motor the window down fully then up fully and hold for approx 10 secs. This should enable the one touch facility. Remember to press down/pull back the button slightly harder as they are basically a 2 stage switch.
  3. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    VCDS is needed to turn on the REMOTE window 'convenience' feature...
    The interior door-button convenience feature can be reprogrammed by holding the buttons. -It's often reset if the battery is changed or disconnected.
    It's not clear from the original post what you mean, but hopefully that helps...?
  4. Ash187
    7,478
    735
    as its a 2010 model have a look on the DIS for any options to enable/disable the convenience option. The newer car DIS has lots of options built into it.
  5. NHN
    29,328
    1,708
    I wouldnt have comfort opening, incase you sit on your keys & then open the windows, to come back & find half the interior gone, comfort closing yes, coding is possible via vcds.
