Auto scan. Can you guys have look for me Please.
dantdi Nov 9, 2011
  1. dantdi
    dantdi ...
    521
    Hey All
    Just got my car back from Audi after having injectors replaced. http://www.audi-sport.net/vb/new-a3-s3-sportback-8p-chassis/137660-how-lucky-am-i-injectors.html
    I've done auto scan with Vagcom.
    Theses faults i have they just from old injectors and audi hasn't reset them ?
    Also worry about the Address 44: Steering Assist one and Address 03: ABS Brakes ? Why would there be faults on them ? Car was fine.
    Wednesday,09,November,2011,15:58:14:64396
    VCDS Version: Release 10.6.5
    Data version: 20110930
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 77
    VIN: WAUZZZ Mileage: 52100km/32373miles
    01-Engine -- Status: Malfunction 1010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
    Component: R4 2.0l PPD1.2 1247
    Revision: --H42--- Serial number: AUX7Z0G3FN4131
    Coding: 0000072
    Shop #: WSC 06441 785 00200
    VCID: 74EDCE006E20
    1 Fault Found:
    004710 - PD Unit Injector: Cylinder 3 (N242): Implausible Signal
    P1266 - 006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 37
    Mileage: 52040 km
    Time Indication: 0
    Date: 2011.11.07
    Time: 14:48:39
    Freeze Frame:
    RPM: 832 /min
    Torque: 48.0 Nm
    Speed: 67.0 km/h
    66.30 %
    Text: 5.250 uF
    Time: 0.00 ms
    Text: 0.00 mJ
    Readiness: N/A
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    Shop #: WSC 06314 000 00000
    VCID: 73EFCD1C6B2E
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
    Component: KlimavollautomatH19 0360
    Revision: 122426 Serial number: 8P0820043AC
    Shop #: WSC 00000 000 00000
    VCID: 6DDBDB640D0A
    No fault code found.
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000006956116
    Coding: 01884F07A014100000000000000000000008FE175C0100
    Shop #: WSC 06314 000 08192
    VCID: 408552D06A18
    Part No: 8P2 955 119 E
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 121
    Mileage: 52040 km
    Time Indication: 0
    Date: 2011.11.07
    Time: 14:38:00
    Freeze Frame:
    ON
    Voltage: 12.00 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H13 4220
    Revision: 91H13422 Serial number: 0037W0G1B1F0
    Coding: 0071612
    VCID: 479749CC4F36
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004012
    VCID: 418357D46112
    Part No: XXXXXXXXXXX
    Component: E0221 H07 0090
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
    Component: KOMBIINSTR. VDO H20 0570
    Revision: D0H20004 Serial number: 2243G004014643
    Coding: 0004418
    Shop #: WSC 00441 067 57207
    VCID: 3B7F253C03FE
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H12 0170
    Revision: H12 Serial number: 33001074020047
    Coding: 3D0F03C207000101
    VCID: 2F67016CC786
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 121
    Mileage: 52040 km
    Time Indication: 0
    Date: 2011.11.07
    Time: 14:38:35
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20004 Serial number: AUX7Z0G3FN4131
    VCID: 3B7F253C03FE
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000560
    VCID: 408552D06A18
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.079 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 356B330425DA
    1 Fault Found:
    Freeze Frame:
    Mileage: 52030 km
    Temperature: 10.0°C
    Voltage: 12.00 V
    Voltage: 11.80 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 F
    Component: KSG H08 0070
    Coding: 1880202002186D088505488AC637
    Shop #: WSC 00857 210 91343
    VCID: 3F87512C17E6
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH27 0160
    Revision: 00005 Serial number: 30659635814998
    VCID: F0E542109A38
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000560
    VCID: 418357D46112
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
    Component: R Concert2+ H02 0270
    Revision: 00H02000 Serial number: AUZ1Z3H8884904
    Coding: 0610311
    Shop #: WSC 00441 210 61830
    VCID: 3F87512C17E6
    Address 77: Telephone Labels: None
    VCID: 55AB9384859A
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    End ---------------------------------------------------------------------
  2. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    As both faults occurred at exactly the same mileage I'm inclined to think it is something they have done.
    Clear the codes and see if they come back.
  3. dantdi
    dantdi ...
    521
    Sorry sound like noob. But im new to vag-com, How do i go about doing that Warren?
    Just wondering would them faults come up because they disconnected the battery?
  4. warren_S5
    7,210
    2,488
    Unlikely they'd come up from battery disconnection, more likely that they did something like turn the ignition key to standby when things weren't connected.
    Do you have VCDS?
    If so run an autoscan to identify error codes, then click to clear DTC's and see if they come back. There's a guide on the RossTech website.
  5. dantdi
    dantdi ...
    521
    Thanks Warren try that tomorrow. Yes i have Vcds
  6. dantdi
    dantdi ...
    521
    Ok i've cleared the faults. But Have they gone ?
    It done auto scan then i del the faults
    Thursday,10,November,2011,08:34:38:64396
    Chassis Type: 1K0
    VIN: WAUZZZ8P Mileage: 52100km/32373miles
    Coding: 0000072
    VCID: 74EDCE006E20
    Readiness: N/A
    Revision: 00H11001
    Coding: 0023170
    VCID: 73EFCD1C6B2E
    VCID: 6DDBDB640D0A
    VCID: 408552D06A18
    Coding: 00062736
    Shop #: WSC 06314
    Coding: 0071612
    VCID: 479749CC4F36
    Coding: 0004012
    VCID: 418357D46112
    Coding: 0004418
    VCID: 3B7F253C03FE
    VCID: 2F67016CC786
    VCID: 3B7F253C03FE
    Coding: 0000560
    VCID: 408552D06A18
    VCID: 356B330425DA
    VCID: 3F87512C17E6
    VCID: F0E542109A38
    Coding: 0000560
    VCID: 418357D46112
    Coding: 0610311
    VCID: 3F87512C17E6
    VCID: 55AB9384859A
    No Faults Found
  7. warren_S5
    7,210
    2,488
    All looks good to me, no fault code found at the bottom of every section. Open to a second opinion.
    Just keep in mind that a car can have issues and not throw a fault, so the only way you truly ever know that a car is operating at its best potential is to do some data logging, but having no fault codes is a step in the right direction. Take it for a drive and see if she feels OK, and if she does the chances are she is.
  8. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,382
    214
    Did you take it for a run after clearing fault codes and then re checking them ? As warren says , all is fine now but double check tomorrow after its done a few miles. shoddy of audi not to reset codes before returning the car. If they didnt clear them they almost certainly didnt check them so if you had the dreaded code " P1276348, Bomb attached to underside of car" you could be looking for a new car now !!
  9. mike foster
    3,967
    Run another autoscan and the malfunctions should disappear. Previous faults were thrown up due to lack of communication with engine control module which was probably temporarily disconnected for some reason.
    Your car shows no faults so unless you know of something happening that shouldn't I would say it's fine.
  10. dantdi
    dantdi ...
    521
    Thanks Guys!! :beerchug: Just been out in it so run scan in min. Car feels fine no light on dash.
    Yeah Paddy, As much as thankfull for audi doing them. EastKent Audi are shoddy! Last time they had the car come back with lights on the dash!
    Thanks again!!
  11. dantdi
    dantdi ...
    521
    Yep done scan again to day. 0 Faults! :o.k:
  12. NHN
    29,577
    1,779
    As already mentioned, they're just remnants from the injector work, dont worry :)
