Auto lock problems
wallacr Jul 1, 2007
  1. wallacr
    wallacr Member
    260
    Hi All,
    I bought a cable from Ross-Tech and used it with Vag-Com to enable the auto lock feature at 15MPH, which worked.
    I did this by adding 32 to the number, as the vag-com tool tip thing suggests and it works, but if I stop and unlock the doors to let someone in, the doors don't seem to re-lock when I drive off again.
    Is this normal? Or is there something I can do to make it re-lock when I drive off again after manually unlocking?
    I've got a 2001 (51 plate) A4 1.9 TDI (130BHP) B6.
    Cheers,
    Rich
  2. garratt83
    garratt83 Member
    244
    Hi mate
    Same on mine
    Don't think you can do anything about it
  3. batwad
    batwad Member
    864
    Yep, that's how mine work.
  4. wallacr
    wallacr Member
    260
    Thanks for replying guys, it's good to know that it's nothing I've done wrong, although it's a shame it can't be sorted. Oh well...
    Cheers,
    Rich
  5. Jimbo.King
    Jimbo.King Active Member VCDS Map User
    269
    50
    This does the same on mine, i have programmed the wife's A2 and this re-locks itself after been unlocked.
    So the conclusion i have come to is if the central locking is air operated it will only lock once until the ignition is turned off and the car re-started, but if the central locking is electronically operated (as the A2) it will re-lock its self when you set off again without re-starting the car.
  6. wallacr
    wallacr Member
    260
    Thanks Jimbo.King
    It's a shame that there is no work around for this.
