Auto lock disable
Aidy06 Sep 15, 2013
  1. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    Can I disable the auto lock feature on my A3 using VCDS? The one where after a certain while the car locks automatically if you don't lock it manually? Thanks
  2. NHN
    29,328
    1,708
    Yes.
  3. Aidy06
    412
    19
    What do I need to change Nigel? It's not for me but my partners sister who managed to some how lock her baby and key in the car last week :think:
  4. NHN
    29,328
    1,708
    Check in 09 or 46 for auto lock 15kmh.
  5. hades-
    9,481
    646
    was the baby driving ?
    as it dont lock till your doing above 1o mph
  6. Aidy06
    412
    19
    I think we are talking about different auto locks, when she parked up and got out of the car her phone rang so she answered it and left the keys on the seat and closed the door as it was raining. The car locked itself after around 30 seconds she said, I've tried it with my car - got out car and didn't lock the doors, stood there for a while and the car locked itself. This is the auto lock I'm talking about
  7. hades-
    9,481
    646
    only auto lock i know of is
    if you unlock the car and dont open a door then it locks itself after so long
    then the one where you drive away and it locks above 10mph
  8. Aidy06
    412
    19
    Well there's another one where the car locks itself if you don't lock it manually after a certain amount of time, just can't see an option in VCDS. May not even be changeable
  9. hades-
    9,481
    646
    out of all the audis iv owned and used and thats 30+ new to old
    not one has ever locked in this way
    iv got a 2010 black edition on the drive i put my work bag in it 45 mins ago and didnt lock the car just been back out and its still unlocked
    so only settings in vcds to stop auto locking is the one for locking above 15kph
  10. NHN
    29,328
    1,708
    It does auto lock tbh bez, mine does it :)
  11. hades-
    9,481
    646
    i just thought id try it on the 10 plate it didnt lock and looked through vcds
    couldnt find a thing only the 15 kph
    iv got all 3 open now to see thats a 55 plate the 10 plate and the b8
    gona check them when i go to work at 1030
    only locked if i didnt open a door
  12. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    My Wifes mk4 Golf auto locks again if you open door and close it without turning ignition on.
  13. NHN
    29,328
    1,708
    The label files for 8P's may not be correct or complete as I've asked RT to check this, when I had issues with a module.
  14. j4g3d
    j4g3d Member
    240
    Solution for this guys?
  15. NHN
    29,328
    1,708
    Solution is to decode the option with vcds.
  16. j4g3d
    j4g3d Member
    240
    Thanks, which option? any guide? please post or PM me if you know anything more. Thanks
  17. franko180
    franko180 Member VCDS Map User
    46
    In this case I can say for sure that this is actually a fault. Yes the MK4 Golf will auto lock if you unlock it and don't touch it, it will lock itself again. However if you open a door it should cancel the auto lock if behaving normally, to attempt to prevent you from locking your keys in the car. If it still auto locks after you've opened and closed a door its because your car has a faulty door lock module, its a very common fault as these cars are 13+ years old and the module's are prone to dry solder joints..
  18. j4g3d
    j4g3d Member
    240
    But how to physically turn this feature off completely? must be a coding within a ecu that can be changed/edit/adjusted to stop this feature?
  19. franko180
    46
    You can code out the anti hi-jack auto locking that locks after a certain speed, but I've never tried to code out the auto lock for when you lock the car but don't open any door.
  20. franko180
    46
    That should "when you UNlock the car but don't open any door" :)
