Auto lights/wipers/dimming rear view mirror & CH/LH install complete!
ADi Nuff Valves Oct 21, 2012
  1. BetyOops
    BetyOops New Member
    I really don't know ... I think i made the same coding than yesterday ... But today it works :)
  2. oskaro
    oskaro New Member
    Hi,
    I do have the same problem as you had BetyOops.
    Everything is installed as it should - followed by instructions provided in this topic. Coming / Leaving home function is working fine together with light sensor. I set "Brightness threshold for Coming Home / Leaving Home" value to "3" (adaptation channel 13) - below that lights are turning on / above it there're not.
    Unfortunately driving lights are ON all the time, even if measure value block 8 shows "Brightness = 7 (maximum)".
    Measure value block 16 shows Light sensor -Lin signal = ON (on=dark).
    I live in Poland where for last few days is cloudy and a bit dark for the whole day. I didn't have a chance to test it during a sunny day. Do you think it matters? Maybe more IR light with right level of intensity and light distribution angel. Does it matter?
    Looking forward for your suggestions. Thank you in advance.
  3. andyduff88
    andyduff88 New Member
    Hi Rob
    Just bought an 11 plate Audi rs3 that does not have auto lights or wipers pack (no auto option on light switch, no auto dim rear view mirror).
    If I contact Audi Manchester with your list above for the conversion and buy the appropriate windscreen buy would that be enough to give me auto lights and wipers option back? I.e. is your list for an rs3 11 plate or would I simply go through your list a d ask them to duly priced and part numbers for rs3 equivelant set up. I have someone who can retrofit all this . Many Thanks Rob, my first post on here and I think your list is really helpful!! Andy
  4. RobRS
    RobRS Member Audi RS3
    Hi Andy,
    Hope you are enjoying your RS 3?
    My RS 3 already came with the Auto Lights & Wipers as a factory fitment.
    The list of parts needed & instructions to fit Auto Lights & Wipers were for an (8P Chassis) MY08 S3 whereas the RS 3 is an (8P & 8V Chassis)
    However, some of those parts are common to both Chassis types -
    8R0 857 511 4PK - Auto-dimming mirror (black) £177.47
    8K0 955 559 D - Rain Sensor £145.56
    4F0 907 671 B - Retaining clip for sensor £2.32
    4F0 857 593 J 4PK - Plastic cover for wiring (black) £4.72
    4F0 857 593 G 4PK - Cable guide $4.66
    The Lights switch will be different & the wiring to the CE module will be different. Sorry, I don't have the wiring details for an (8P & 8V Chassis) CE module, but I would have thought you'd be able to find them on here quite easily?
    Best of luck with your retro fit
  5. Golfather
    Golfather Member
    75
    Just to update this thread, this is a real easy upgrade for any Audi A3 facelift 8P3 2009 onwards. So S3, RS3 etc.
    Don't need a headlight switch, original DRL switch will work and is already wired up. No coming home button required.
    Only wiring required is the tap to PIN 33 Socket B for the LIN bus for your rain sensor.
    Enable coding.
    Thats it.
    Retrofitters may want to adjust their prices when quoting for work for the above models.. ;)
  6. -Ju-
    -Ju- Well-Known Member Team Panther VCDS Map User Audi S3
    2,372
    493
    I really need to get mine finished. I've had all the main parts for ages and basically just need the screen.
    I did go into autoglass who were ok to do the windscreen, as it has a decent chip on it, but would only do like for like according to chassis number.
    I also want a genuine screen does any one know the cost of this?
  7. dandav1985
    dandav1985 Active Member Team Panther TFSI Owners Group VCDS Map User Bronze Supporter Audi S3 s tronic
    435
    94
    Hello Lads,
    Been a while, I have a 2010 s3 with auto lights, wipers, interior and exterior dimming mirrors. I wanting to upgrade the mirror to the high beam assist and compass mirror. Anyone have the part Number for this mirror and does it require any extra wiring.
    Cheers Once again.
    Dan
  8. -Ju-
    2,372
    493
    Finally got a new screen fitted so I will be completing this once I get my ageing head around the wiring!
    As my car is an MY10 I believe the wiring is slightly different to the earlier models.
    This is what I've figured so far (correct me if I'm wrong)
    6 pin connector from the mirror
    1 - Fuse 4
    2 - Earth
    3 - CE module block C pin 28
    4 - door module .....not needed as I don't have dimming door mirrors
    5 - door module .....not needed as I don't have dimming door mirrors
    6 - illumination for the button on the mirror ......... pin 1 In the overhead interior light connector?
    3 pin connector from the sensor
    1 - connection 1 (30A) in the main wiring harness.......no idea where that is! (Can I just tap in somewhere else?)
    2 - earth
    3 - CE module block B pin 33
    I have the kufatec loom without any instructions or loom markings
    I take it I will need some repair wires to make the connections to the CE module?
    Please feel free to correct me or offer any advice
  9. Ash187
    7,505
    748
    6 pin connector pin 6 not needed, can be left disconnected.
    3 pin connector pin 1 goes to fuse 16
    everything else is correct
    -Ju- likes this.
  10. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Ash, do you have the wiring info for a 2008 TDI by any chance?
  11. Ash187
    7,505
    748
    1 - Fuse 4
    2 - Earth
    3 - CE module block B pin 1
    4 - both front door modules 20 pin plug pin 1 .....not needed as I don't have dimming door mirrors
    5 - both front door modules 20 pin plug pin 10 .....not needed as I don't have dimming door mirrors
    6 -
    1 - fuse 16
    2 - earth
    3 - CE module block F pin 3
    phil miller likes this.
  12. -Ju-
    2,372
    493
    Is pin 6 so the mirror knows when the inerior light is on and so doesn't dim?
    Thanks Ash your a star:rock:
  13. phil miller
    1,211
    166
    That is awesome, thank you ash
  14. Ash187
    7,505
    748
    That's what it's meant to do but in my old A3 I couldn't get that to work. Also the wiring diagrams doesn't have pin 6 listed anywhere
  15. -Ju-
    2,372
    493
    Just finished the install, I believe it's all working but not had chance to check the operation properly. A cup of water on the sensor works though lol
    Thanks again but prepare for more questions when it's not working properly haha
  16. phil miller
    1,211
    166
    Ok does anyone know IF its poss to get a headlight switch that does auto lights, front and rear fogs, CL lights that has a chrome switch? ive bought one and when i connect it up my lights are one all the time, is this coding or is this because the switch is no good?
  17. phil miller
    1,211
    166
    All fitted, mirror is dimming, and when the wiper stalk is in position 1 (now auto wipe) the wiper arms move when i turn the ign off, so i think its all working :)
  18. Egbert
    Egbert Member
    34
    Hi all, I am currently doing this retro-fit in a 2011 A3 (2.0 TDI) but I am having problems figuring out the location for pin 3 on the six pin socket from the mirror. I have seen various info on what the location should be:
    Fuse 7(???)
    CE Block C Pin 28
    CE Block C Pin 12
    Which one is correct?
    Many thanks
  19. -Ju-
    2,372
    493
  20. Egbert
    Egbert Member
    34
    Brilliant - thank you. I will update once its all fitted.
  21. -Ju-
    2,372
    493
    Mine works a treat, it's a bit awkward soldering the cables into the CE unit but with a little patience it's not too bad
    Ours being the 8P3, is wired different to the earlier models, hence the confusion
  22. Egbert
    Egbert Member
    34
    I just need the mirror cable trim pieces then I can start the process. I don't have the correct light switch yet but in the short term I'll just use the DRL position as auto.
