Auto door locking
Steve-L Jul 28, 2006
  1. Steve-L
    Steve-L Member
    93
    My previous car (LCR) had a security feature whereby the doors would automatically lock when the engine reached 2000 revs, can the A3 be programmed to do this as well ?
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,091
    2,541
    Yes it can, either by a dealer or by using the VAG.com software that many of the people here have.
    The doors automatically lock when the car reaches about 10mph, & then unlock when the key is removed from the ignition.
  3. Steve-L
    Steve-L Member
    93
    Thanks, the dealer told me it had this feature but obviously its not programmed so I guess they should do it FOC.
  4. Amchlolor
    Amchlolor Active Member
    5,604
    Is your car used,or older ?
    My 05 Sportback did it as standard,which I thought they all did,but I had the dealer switch it off.
    At the same time,I had them switch on the alarm beep (little beep that confirms doors are locked,in addition to indicators).
  5. Steve-L
    Steve-L Member
    93
    Its an 04 plate, I also noticed that there is not any flashing bulb inside the car that indicates the alarm is active, maybe this is normal though.
  6. Eeef
    Eeef Lord of War
    1,607
    My 05 didn't do it, so i took it back and asked them to change it, which they did foc.
    There is a flashy light for the alarm but it's not that obvious. It sits on the front of the dash and is only visable from the front of the car.
  7. Amchlolor
    5,604
    Imagine being on the space shuttle.
    Imagine then trying to pick out your mate flashing a torch.
    That's the A3 alarm LED,that is.
  8. wilko
    wilko Top Gear
    725
    Can you get the 3 door doors to auto lock? Thought it was just a "sport"back feature.
  9. marriedblonde
    marriedblonde Active Member
    4,371
    LOL...thats the best decription so far.
    And when he says in the space shuttle, he means in orbit not on the launch oad!
  10. d3fy
    d3fy Active Member
    1,412
    Mine autolocks as standard (MY06)
  11. johnmv55
    johnmv55 Member
    247
    My last one auto-locked (3 dr 2.0fsi 53 plate) and my current one also now does after I asked it to be "programmed in" I think you can get it programmed in a number of ways i.e lock at 10mph, unlock manually (women apparantly remove the ignition key and sit there fiddleing with handbags etc!) or lock at 10 mph, and unlock with ignition key removal, its woth asking as I suspect there may be many combinations
  12. marriedblonde
    4,371
    Yep there is, mine has autolock set. Push the button to unlock and only the drviers door unlocks, press twice and tehy all do. Drive off and all doors lock when I hit 10mph.
    Remove the ignition key and only the drivers door unlocks. You can program it so all doors unlock.
    J.
  13. Steve-L
    Steve-L Member
    93
    Thanks for the info guy's, have spoken to the dealer and arranged to take the car to my local dealer to get it reprogrammed early next week FOC.
    :beerchug:
  14. benw123
    benw123 Moderator
    1,863
    That's different to mine, so there must be lots of combinations! Have auto-lock at 10mph, but pressing the unlock button inside or on the fob unlocks all the doors.
    I assume VAG-COM is used to reprogram it? On my old Focus ST170, you could set the auto-locking feature by pressing the interior lock three times with the door shut and the key in the ignition, and then the same again without the key! :)
  15. hburnett
    hburnett Member
    45
    Same here. Mine came with this automatically...
    Bowfer didn't know they can program the alarm to beep when the doors lock.. It's going for it's 1st service sometime this month so I get them to do this.. Nice one!
    H
  16. Amchlolor
    5,604
    Superb addition,in my book.
    There are those that argue the indicators flashing should suffice,but the bleep takes any doubt away.
    Also dead handy when I check my car is locked at night,as I can't see the indicators from my door or windows.
    Saves me having to walk outside in my Girls Aloud jim-jams.
  17. jdp1962
    8,091
    2,541
    LOLOLOL!!!!!
  18. mandyray
    mandyray Member
    196
    My car is booked in for a day in a couple of weeks due to a faulty bonnet switch/sensor. Do you think they will switch on the alarm beep at the same time FOC? I'm also considering getting the key fob unlock changed so it opens all doors on one click, as opposed to just the drivers door - it really annoys my other half when I forget to double click!
  19. wilko
    wilko Top Gear
    725
    See mine doesn't do that either! How come every car is so different?
  20. marriedblonde
    4,371
  21. Amchlolor
    5,604
    Don't see why not.
    For the record,I have;
    Alarm beep on
    Autolock off
    One click locks/unlocks all doors.
  22. wilko
    wilko Top Gear
    725
    Interesting... so many options that surely we (the customer) should choose whether we want them enabled or not?!:think:
  23. h5djr
    9,239
    1,627
    It may well be that the customer cannot choose from the full list as this would infringe the Type Approval. I noticed for example that two of the codes relate to Daytime Driving Lights - one for the Scandnavian market and one for the North American market.
    I must say that when I bought my A3 back in 2004, the dealer explained all the options in connection with door locking and asked me how I wanted mine set-up. I decided to have 'auto-locking' but later found it to be a nuisance and so had it programmed out. I also prefer just the one press of the remote to unlock all doors.
  24. Amchlolor
    5,604
    I believe the alarm bleep may be (technically) illegal,as I think alarms are only supposed to have visual signals for arming/dismarming now.
    That didn't seem to bother my dealer though,and I'm glad of it.
    They wouldn't play ball with the seat belt 'bing bing bing' though.
    They just refused to switch that off,no matter how much I asked.
    Busturds.
  25. Covenant
    Covenant Member
    246
    Seatbelt chimes are turned off on my newly-delivered SLine :D
  26. skanky
    skanky Member
    387
    got a source for that?
  27. Vertigo1
    Vertigo1 Well-Known Member
    3,381
    542
    And why do you want it switched off exactly?
  28. god_thats_quick
    2,507
    Your neighbours must love you! :friends:
  29. Amchlolor
    5,604
    Coz it annoys me
    I don't need some poxy noise to remind me to put my belt on.
  30. Vertigo1
    3,381
    542
    But if you put your belt on before driving off, as you should, you'd never hear it
