Auto Closing Windows
sachen Mar 4, 2011
  1. sachen
    sachen Member
    246
    So my car used to close its windows when you lock the car and i believe keep the lock button pressed, but it doesnt do this anymore... anyone know why and how this can be re-enabled
    I have a 06 A3 Sportback.
  2. Farhan
    Farhan Active Member
    1,234
    57
    Mine doesnt do this either, maybe it needs to be reset on a vag-com or something?
  3. BlueSpark
    BlueSpark 6th Gear
    386
    This is the first mod i did when i got vagcom. You have to code via vagcom for comfort closing windows via remote..or something similar in central electrics i think. This will allow you to close the windows by pressing the lock button until it starts rolling then let go and it will continue closing by itself.
  4. BlueSpark
    BlueSpark 6th Gear
    386
    Found this:
    Operating Windows and Sunroof with Remote
    (Note, the sunroof cannot be opened with the remote)
    You need to continuously hold the remote button for the function to operate.
    [Select]
    [46 - Cent. Conv.]
    [Long Coding - 07]
    [Long Coding Helper]
    Click on each of the Byte numbers in step 3) and you'll see the selectable options below.
    Uncheck the box for "Comfort function power windows/sunroof via remote control inactive"
    Check the box for "Comfort opening power windows via remote control active"
    Check the box for "Comfort closing power windows via remote control active"
    Check the box for "Closing sunroof via remote control active"
    [Transfer Coding]
  5. mike foster
    3,967
    I think you have to reset every time if you have disconnected the battery for any reason !
  6. roman3000
    roman3000 Member
    316
    If the windows don't close with one touch when your driving then they wont close via the fob. To reset them fully open and close the windows a couple of times by holding the window switch and it should work after that.
  7. Farhan
    1,234
    57
    i need a best friend who owns and knows how to use a vag-com. I have started a best friend shortlist who wants to join :)
    requirements must own and be able to use a vagcome lol
  8. NHN
    29,399
    1,738
    Yeap, check if one touch is working on all 4 windows, even if 1 window isnt working on one touch, then it stops the whole system from closing as mentioned.
  9. Phil-1
    Phil-1 Well-Known Member Regional Rep
    2,027
    668
    Just collected my 09 plate A3 this evening and was surprised that it doesn't have comfort close.
    It's raining so will check the one touch widow thing in the morning.
  10. Jkevs
    Jkevs Member
    100
    13
    Mine did it then stopped one day. Had a search around on here and you have to have the windows closed, open them fully then close them and hold the switch up for 15 seconds. This should kick them in.
  11. sliced
    sliced Drive safe, stay alive.
    1,562
    334
    I swear this can be enabled and disabled by the DIS
  12. Phil-1
    2,027
    668
    Ok. Daft question what is the DIS?
  13. Phil-1
    2,027
    668
    Ok. Reset the windows by opening them fully and then closing then from the drivers controls. But it's still not working. Could this be a VCDS issue?
  14. fangio
    fangio Well-Known Member
    1,507
    180
    With mine, I have to press to lock then press again and hold to close the windows. i.e. lock the doors then close the windows!
  15. Phil-1
    2,027
    668
    I have just been holding the button.
    Will try it now
  16. Phil-1
    2,027
    668
    No still not working ;-(
  17. sliced
    1,562
    334
    Phil-1 likes this.
  18. Phil-1
    2,027
    668
    What an idiot I am.
    Just found all this. Still finding things on it ;-)
  19. sliced
    1,562
    334
    haha no worries, let us know if makes the auto closing windows work!
  20. Phil-1
    2,027
    668
    Just changed this and the unlock feature. All working great now.
    I love it when you are still finding things on a new car.
  21. fangio
    1,507
    180
