Auto Close windows on A3?
Diamond May 18, 2010
  1. Diamond
    Diamond Member
    294
    Hi,
    On my current Ford Focus if i leave the windows down after getting out of the car and press and hold the locked button on my key fob its not only locks the doors but also send the windows back up. Does the Audi A3 have this?
    Thanks:icon_thumright:
  2. dave_ph
    dave_ph Member VCDS Map User
    78
    10
    yup, also same for unlocking - winds down the windows. also if you have a sunroof, it will open and close that
  3. Brian566
    Brian566 Member
    70
    Just remember if it has had the battery disconnected the windows have to be reset as in the manual
    If not the Auto open and close from key will not work
  4. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    You can also enable the auto closing option using VCDS to save you having to hold the key until they close.
    Paul
  5. qennu
    qennu Member
    178
    any ideas how to do it mate ?
  6. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    As GTI Jazz said, to enable full-closure without keeping your finger on the button you need VCDS.
  7. djlazyp
    djlazyp New Member
    27
    anyone know what control mudule setting its under in vcds ?
  8. Ash187
    7,518
    750
    If i remember correctly it is under Central Electrics -09.
    you need to go to the long coding helper and look in there. I enabled mine a couple weeks back and it works fine. need to hold button down for about 2 seconds and then once it starts winding up let the button go and it will fully close the windows.
  9. Brett Butler
    Brett Butler Member
    664
    13
    it is annoying that these things cannot be set up but the owner once they have the vehicle
  10. jb0o
    2,664
    118
    Its under Central Convinience - 46 on VCDS,
    Click on 'Coding' then 'Long Coding' and flick through the options available and its there somewhere..
  11. Diamond
    Diamond Member
    294
    Sorry for been dumb, but what is VCDS?
  12. jb0o
    2,664
    118
    Not being dumb at all mate.
    VCDS (formely known as VAG-COM) is a tool that connects a computer to your VAG car and allows diagnostics and other stuff such as tweaking etc.. really good tool and well worth the investment!
  13. Diamond
    Diamond Member
    294
    Many Thanks!:icon_thumright:
  14. jb0o
    2,664
    118
    No problem, check out the VCDS thread, a cool guy on here called NHN sells VCDS, at a good price too so I hear, might be worthwhile checking it out if you're interested!
  15. bambam
    bambam Member
    123
    I've read it before somewhere but to save searching for it how do you reset the auto windows via the switch?
  16. jars
    jars Member
    open and shut the particular window several times. I just kept doing it until it worked!
  17. djlazyp
    djlazyp New Member
    27
    NICE ONE WILL ENABLE MINE NOW
  18. qennu
    qennu Member
    178
    I wonder how that cheap VCDS, VAG COM on ebay and made in china works lol
  19. Ash187
    7,518
    750
    to reset it you need to open and close the window once.... hold the switch down all the way till its open and then all the way up again until its closed in one motion. it should then work on the one touch open/close.
    You will need to do it to every window.
  20. bambam
    bambam Member
    123
    thanks!
  21. Gti Jazz Blue
    1,655
    Not very well.
    Buy the genuine cable, it is worth it for the support alone.
    Doesn't take many visits to Audi at £40-£50 a go to pay for a genuine cable.
    Paul
  22. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    I've Looked in Central Electrics -09 & Central Convinience - 46 on VCDS. And it's all blank in the Long Code Help. Can Somebody give me the code so I can Manually put in the code ?
  23. qennu
    qennu Member
    178
    Yes Pauls I know cheap stuff is never worth the risk,espically on a car.
    Will buy a genuine one when funds allow as buying so much things at the moment
